Old 25th May 2003, 09:06 AM   #1
Default Help wiring this speaker
I am making a speaker using four 4" Tang Band full-range 8 ohm drivers, with a helper tweeter to cover the highest frequencies that I know these TB's don't seem to reach too well.
How can I wire these up with as little extra hardware as possible (hopefully just a filter on the tweeter at the most) and keep a safe ohm load?
I could do it with just the 4 drivers, but adding the tweeter confuses things a bit.
Any ideas?
Old 25th May 2003, 11:18 AM   #2
MadMax is offline MadMax  New Zealand
what tweet are you using and whats the app your using them for.
Are you going to hook drivers in a parrell/ seiral config.
Cheers Max
Old 25th May 2003, 11:57 AM   #3
diyAudio Senior Member
fdegrove's Avatar
Assuming you want an 8 Ohm impedance you will need to hook up two pairs in series, this will give you 2 x 16Ohm units.
After that putting the 2 pairs in // will halve Rtot so you'll end up with 8 Ohm again.
As far as the tweeter goes, a simple series cap will filter out the bas.
The smaller the cap the less bass it will let through.
Without knowledge of the units used I can't tell anything more than this.
Frank
Old 25th May 2003, 05:20 PM   #4
swirv's Avatar
Send a message via AIM to swirv
What TB drivers are you using?
What tweeter have you picked?
I build some nice sounding speakers using the W4-656S and 28-847S. Simple series eries XO @ 6500Hz.
Chris
Old 26th May 2003, 07:02 AM   #5
I don't remember the model number of the drivers but they are the four inchers with the black phase plug, not the chrome.
I am thinking that for a tweeter I might try the LPG from Madisound that you can get a surface mount for because I like the idea of mounting the tweeter on top of the speaker so I can just avoid alot of baffle reflection problems, and with the tweeter mounted atop the center chennel it won't limit the lateral dispersion as bad, even thought the tweeter won't be playing much at all. Only the very top end that the 4's can't reach.
I made some little towers a few months ago that used the 4's with the chrome phase plug and they sounded pretty good by themselves, but they lacked ay real sparkle in the upper register, so I slapped on one of my extra Lineaum dipole tweeters on each one and it totally fixed the problem and sounded quite good (although the transition between the drivers was a bit off).
Speaker wiring help please dave13 Instruments and Amps 4 21st May 2009 10:04 PM
HELP speaker wiring conundrum I_Just_Am Instruments and Amps 1 27th February 2009 04:50 PM
Vintage Speaker Wiring 80sboy Multi-Way 5 22nd July 2008 01:14 AM
Mutiple Speaker Wiring louee6 Subwoofers 2 6th April 2007 05:10 PM
Page generated in 0.09037 seconds (74.64% PHP - 25.36% MySQL) with 10 queries
