#9911 | |
I thought it is reasonable to first get a feel for the issue and then determine whether it is worth it. If the measurements (which cannot be discounted so easily as an unreliable, uncontrolled, anecdotal listening test by one or two guys) show a substantial difference, I'm willing to invest some time. Not on a ghost hunt. Edit: If the measured differences are substantial, I may even agree right away that they would be audible. Howszat? jd
/Another new issue: Linear Audio Volume 3! Last edited by janneman; 24th December 2009 at 02:04 PM. |
#9912 | |
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#9913 | |
![]() Just seen your post SY.DO the biwiring test with a cheap 12awg and a cheap 16awg wire.You will still hear the difference clearly. Last edited by Panicos K; 24th December 2009 at 02:08 PM. |
#9914 |
Panikos, will your suggested experiment work with a multiamp system (e.g., mine)?
#9915 | |
I think I made my reasoning clear. If you chose to use words like 'simply shows you just don't dare to put your belief in measurements in doubt', there's not much I can do. Certainly these words will not propel me to suddenly do the test. You need to try better Try 'religious' for instance, I understand some are sensitive to that jd
/Another new issue: Linear Audio Volume 3! |
#9916 | |
SY,we are talking about same amplifiers for each speaker input,right? Last edited by Panicos K; 24th December 2009 at 02:36 PM. |
#9917 | |
It is the only countermeasure against running in circles. ![]() Wishes P.S. Maybe that you need a "triple blind" to listen against your bias. |
#9918 | |||
#9919 | |
#9920 |
| Page generated in 0.21798 seconds (70.61% PHP - 29.39% MySQL) with 11 queries |
