#981 | |
Are you talking about standarized electrical characteristics in output stages and loudspeaker? Gareth |
#982 |
diyAudio Chief Moderator
And input stages too. Loudspeakers cant be controlled so easily, but there is scope for flatter impedances at least. |
#983 |
A fairly major statement that. Somewhat difficult to implement also. Nonetheless for truly 'un-coloured' sound this would be the way forward, but I feel we would miss some of the enthusiasm found through exploring different designs. I say this based on what I understand you to mean that there really should be only one topology for sources/amplifiers/loudspeakers. Do I understand you correctly? Gareth |
#984 | |
Obviously the "harshness" or the "graininess" I notice is not a simple FR change, but when I hear that the bass and mid bass have all but disappeared how can that happen without an FR change? I don't have to do this you know - I can just duck out of this forum and enjoy my music in my pathetic "beyond naive" state. It's all burned in now anyway thank goodness!
FLAC, Ethernet over Mains, SB3, GD Audio DAC 19, Tubelab SE 45, FE206eN in Scotmoose Sachikos with Fostex FT17h supertweeters 0.68uF cap.
#985 | |
Bass almost disappeared?? I find such statements beyond belief! Plugging in a piece of wire and two connectors can almost remove all frequencies below (say) 200Hz? and then they come back again!! Tht would be measureable with a wet finger! How can any engineer believe that? I wish someone could explain it to me, and I mean -30dB at 200Hz. |
#986 | |
But if MC cartridge manufacturers produce any kind of output impedance and output level on a whim, how can you optimize a phono stage for the market? It has to have 2-3 variable user tweakable parameters just to interface well. The average user has to understand how a phono stage works as much as SY then, so to really optimize and not fool around. As for rights in to playing with coloration, thats a hobby ideal, I understand it, but it will not help this discussion. No reference, is automatically no science. And reference must be transparency. |
#987 | |
#988 |
HI salas,
Understandably there are design specifications that are met by different manufacturers, obviously as it would be mayhem on the sales floor. But I understood that if you standardized topology then all cables would sound the same, no? Gareth |
#989 | |
#990 | ||
Wrote it before. Far less, means not 'same'. We can cut on 'proper' filtering parameters. Quote:
| Page generated in 0.24091 seconds (65.97% PHP - 34.03% MySQL) with 11 queries |
