Closed Thread
Old 8th December 2009, 04:18 PM   #9011
Johnloudb's Avatar
Originally Posted by Jakob2 View Post
I´m sure, you´ve heared (as anybody else) sometimes the story of the recording engineer who had eq´ed the hell out of a song only to notice suddenly that the bypass switch was pressed all the time and that in reality he hadn´t changed a thing. (And that, or something similar, does literally happen to everyone at least once in their lifes)
What can we conclude from that? Yes, humans are prone to sensory errors.
More interesting is what the recording engineers conclude from that story; it is (surprisingly) not that they further should rely only on dbts, but instead to be more cautious than before.
Has happened to me a number of times ... mistakes that is. We make them all the time. We can hear the same sound under different circumstances and respond differently to it - conditioned reflexes.
You´re talking about JNDs? I don´t know if you´ve ever done a series of tests to find out your thresholds, but i´d suspect that you´d have quite a lot of problems to notice every trick that is used during recording/mixing/mastering.
Some of these tricks are quite subtile and i don´t think that qualifies for your analogy.
Or just think of a conductor standing in front of a full orchestra and suddenly he notices that one of the strings doesn´t sound like intended.
Do you think the difference is easy to measure or easy to hear?
And if the sequence is repeated by the orchestra after some time, do you really think they´d meet the former level within a fraction of a dezibel?
I completely agree Jakob!
Yep, we have increased gain for sounds of special importance and how we respond depends on the conditions we hear them.
And, speaking of JNDs, is it a hard threshold and if it is so, is it the same for every person on the world? Or is it more a bell shaped curve and if so what is the spread of the curve?
And if you´re sure that we were testing along the JNDs, could you cite some tests in which it was shown that the participants were able to reach that level of sensitivity?
If you couldn´t, and given the examples of _big_ differences not detected in perception tests (for example from the links i´ve posted before) what do you think can be concluded from those test results?
Wishes
What are JNDs? I'm not familiar with that acronym.
Old 8th December 2009, 04:24 PM   #9012
Do you mean: Toole's book? I have met and debated with Floyd Tool when I was with the AES. Smart guy, on the wrong path.
Old 8th December 2009, 04:26 PM   #9013
Jakob2 is offline Jakob2  Germany
That acronym means Just Notable Difference.
Wishes
Old 8th December 2009, 04:27 PM   #9014
rdf is offline rdf  Canada
rdf's Avatar
Originally Posted by terry j View Post
NO!! NOT amen pavel, NOT well done curly.
HAVE YOU NO INTEGRITY???
At least have a bit of intellectual honesty.
One night's sleep and look where the conversation heads. Integrity, techno-Millennialism, experts on the cross and a more than a little disturbing comparison to Cambodian purges (not a regime founded on religion). Quite the drift.
So for the persecuted experts on board here, have you performed even the most cursory tests of those beliefs? For examples:
- Calibrated your tests with stimuli scientifically proven audible? Or is your certainty about its implementation based on faith? Are test protocols equivalent to your buddy swapping cables behind a screen of sufficient resolution to catch differences proven in the lab to be audible? Or for those fast switching speaker cables via relays, even tried pink/white noise?
- Measured? Simple enough question, has anyone here gone to the simplest first step and measured the frequency response differences between amplifier and speaker terminals, then compared to magnitudes scientifically proven audible?
The whole idiot/expert dualism (as if dualism was in any way scientifically justifiable) this thread has taken is disquieting. The most impressive solid state design chops bestow zero expertise on physiological test protocols. 'Expert' is a statement describing knowledge in a field , not a general statement on your worth. And how could anyone who owns a TV not be hammered by the fact 'expert' means almost nothing? Don't like today what the expert says about the economy/diet/real state/environment? Wait for next tomorrow.
Ears aren't microphones.
Old 8th December 2009, 04:28 PM   #9015
Originally Posted by Curly Woods View Post
Tragic for sure. The sky will soon collapse on us all.
No, what's tragic is that the subjectivist sky has already collapsed and you just won't acknowledge it.
Old 8th December 2009, 04:34 PM   #9016
And if I have not ever done one (I have if it is important) that does not mean you cannot talk about it, design one or critique data.
How do you choose and set up a test system if you don't even believe in stage focus, which just happen to be one of the important aspects where cables can make a difference?
WE (the 'non-believers if you will) ...why do WE have to test for anything?? In any case, even if you are correct that we need to prove YOUR claims, you have already stated the problem. If WE do not hear it, HOW will you ever be able to get us to understand completely what it is you are talking about, so that we can then conduct better tests??? You think I can ever hear what you hear??? And vice versa? I can experience your experience?? no matter how well you describe it, that can never happen.
Who are the WE, how many cable tests have YOU done?
I wish this type of %&*# will get to an end, why must there always be we and you and morons and stupids? I'm here because I would like to learn why there are differences between cables while measurements may suggest there aren't any. Why can't we try and listen to each others views and try and come to a conclusion that will be in the interest of ALL.
The idea of my post was not to suggest "other" must do the testing, my opinion is only that if those that do the testing take what is said here into consideration, the results may just be different. I'm not here to criticise, I would like to help and find answers, I can only give suggestions based on my experiences and what I think may be important to consider if anybody is interested anyway. I've done blind tests several times, they confirmed what I've heard during sighted testing but I also realise it will never be good enough to proof anything. At this stage I see it as a waste of time anyway, I do my testing because I find it interesting and maybe learn something new.
Old 8th December 2009, 04:35 PM   #9017
Curly, we will not only lose our wires, but our speakers too! ;-)
Old 8th December 2009, 04:37 PM   #9018
Steve Eddy's Avatar
That's the Mike Lavigne thread. Not the Michael Fremer thread.
Here's the thread you want to read.
http://forums.randi.org/showthread.php?t=96913
se
Old 8th December 2009, 04:40 PM   #9019
scott wurcer's Avatar
Originally Posted by john curl View Post
Curlyites unite! All you can lose is your wires. ;-)
YouTube - The Curly Shuffle
I hope this thread can still have a sense of humor.
2012, our time is running out.
Old 8th December 2009, 04:41 PM   #9020
Curly Woods:
There have been all types of studies, but nothing that clearly spells out what a human being is or is not capable of hearing.
Nonsense. Plenty of studies show what people CAN hear and plenty show what we can't. I will concede though, that there are probably no studies that show we can't hear in the 20 - 300Mhz region but then, so what? Why would such studies exist? Does their absence mean you're open to the possibility that we might be able to hear in that frequency range or will you admit that we can make definitive statements abour hearing range? Likewise sensitivity to variations in SPL and phase, masking effects etc.
You will have to realize that there are far more people on the planet that do claim to hear differences in audio equipment than do not, but I continue to see things that suggest otherwise, except those that want to prove it us all to be wrong.
Again, it doesn't matter how many people are wrong - if they are wrong. You're repeating the logical fallacy of 'argument ad populum' again. I acknowledge and agree that you experience things that contradict the objectivist/scientific position, I never disputed that fact. What I disputed is that your perceptions were of something real as you claim, and not really the result of your mind playing tricks on you - a possibility you have dishonestly refused to admit for a long time now.
My A/B's are not "blind" but I do them all the time, but not for just a few minutes, but days at a time. I simply do not follow the short term logic as I am aware I am trying to hear differences and it does not work for me.
Your A/** are not blind but, no matter how many times you do them or for how long, the fact that they are not double-blind means they are worthless, as you *cannot* differentiate those of your perceptions that were of something real from those that were not of something real. All of your conclusions are thus unreliable and useless - even to you. That you admit not following 'short-term' logic is a straw-man - no-one ever said DBTs have to be short-term, you could follow a DBT for as long as you felt you needed. You are again being disingenuous. Furthermore, you should not be trying to hear differences - this only makes sense if you are already biased in your testing by assuming that there will be differences. You are leading yourself to false conclusions.
By the way, Curly, for once I'd appreciate a detailed and reasoned response to you on these points, rather than your usual obtuse tactic of a witty reply or no reply. I and others have consistently offered you the courtesy of detailed responsed to your points, the least we might expect in return is the same from you. Like that, this conversation can move forward rather than you just leading everyone in circles.
Closed Thread
Page generated in 0.25763 seconds (69.71% PHP - 30.29% MySQL) with 11 queries
