#8221 | |
Wowie! you found a typo yes the values in the table for R62 and R63 are swapped. Thanks |
#8222 |
Auplater, have you ever read Ragnar Holm's book 'Electric contacts'? If you have not, we have nothing to discuss at this time.
#8223 |
Synopsis?
Yes, conservatism thrives on low intelligence and poor information. But the liberals in politics... continue to back off, yielding to the supremacy of the stupid. It's turkeys all the way down. - George Monbiot, guardian.co.uk, 6 Feb 2012 |
#8224 | |
Banned
#8225 | |
There is a type of plating that I every so often see on the cheap imported connectors that starts out bright and shiny silver and after a while gets a white film. At that point most of the connectors just stop conducting low level signals. Cleaning them so that they work is a very short fix, the oxide comes back. That is what I called bright and shiny it is always interesting to see how others read things and even more interesting to see how those who did not react. By the way what is the conductivity of electroplated copper? It measures different than annealed copper. |
#8226 |
auplater,
Good Lord John! You got off of your rant stand and provided really sensational information! Thank you! Bud
"You and I and every other thing are a dependent arising, empty of any inherent reality" Tsong Ko Pa |
#8227 | |
the cheap=o connectors have either zinc plating or they have a flash coating of tin or solder. Not good, never have used them. Who uses electroplated copper on interconnects? maybe a flash layer if made from steel, but who wants steel terminations. Electroplated copper can be very highly conductive, again it depends on the conditions under which it is produced. Hey, you don't have to believe anything I say, just passing on decades of experience, experimentation, and succesful commercial electrochemistry. Cheers John L.
"...His brain is squirming like a toad..." Jim Morrison |
#8228 |
Who was Holm, and what did he say about gold?
#8229 | |
![]() BTW: I was reading more about meta-materials and how they are used for "cloaking" of objects to make them invisible... Klingon-ish... maybe the EnaBL methodology could be related to cloaking of the bad behavior aspects of the micro-dynamics in the signal, somehow making the main information carrier transparent to their effects? Maaybe rename the process to SoniCloak l8tr John L.
#8230 |
No cable can improve the signal sent through it. 5c pennypinching on the connectors can do helluva job spoiling it.
| Page generated in 0.23103 seconds (68.66% PHP - 31.34% MySQL) with 11 queries |
