#811 | |
Cheers, John |
#812 | |
".........These go to eleven" |
#813 | |
OTOH I don't really see the need to do blind testing for my own personal use. I listened to these two sets of interconnects (Cardas Neutral Reference vs SonicWaves) over the course of a month and I'm quite confident that I prefer the cheaper cords. I wanted to have a reason to justify the expensive wires, because my audiophile friends won't get it, and I've already spent the money. But alas the cheap wires were better.
Dan |
#814 | |
Custom Title
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned! |
#815 | |
If by ABX testing you mean as normally understood and defined in this Wikipedia entry about codecs:
I agree. |
#816 | |
I find it strange people advocating this routine when it is well known that our signal processing can adapt to the quality of input and still extract the pertinent information, and that after a while the original heard quality differences (if they ever were audible) just are not perceived anymore. In this instance - what would the protocol be? Two months, years or centuries with cable a, the same with cable b and then make an assessment of the differences? |
#817 | |
For this test I used an Aikido line stage with 6FQ7/5687 tubes with a set of modified Quicksilver 8417 tube amplifiers driving a pair of cloned Klipsch Cornwall speakers. Note* The clone speakers measure almost ruler flat for response. I also tried this with a modified Dynaco stereo 70 amplifier and numerous Solid state amplifiers of which I have stacks of. My opinion of the high priced over rated cables hasn't changed as of yet. |
#818 | ||
Alasdair Patrick of Audioquest summed it up best: "Of course, you can choose not to believe, but you'd be missing out on so much." In plain English, there's no difference between cables and religion. It's all about faith. Of course, faith is the opposite of truth. There's no hope for this unbeliever. Quote:
This bozo picked up on the improvement right away. "One thing you learn in the professional music business (I've been in the National Symphony for 21 years) is that artistic honesty and integrity are everything. Without it, you're just a hack. Well, I confess: I screwed up. After finishing all my listening comparisons during the preparation of this review, I went through the snakepit of cables behind my two equipment cabinets and, to my chagrin, discovered that the Mark Levinson No.26S preamp had been plugged into a non-dedicated circuit via an el cheapo power cord, going through an Adcom ACE-515 AC Enhancer. With all due haste, I reconfigured the AC connection from the No.26S with the correct Tiffany cord, into a 15 amp dedicated circuit. What a difference! The sound was more open, more dynamic, and more listenable, lending credibility to the argument that dedicated circuits and high-quality power cables really can make a difference. I started out with a new slate. To hell with the fact that I'd already spent hundreds of hours listening and comparing the Cello with the Mark Levinson, or that my NSO colleagues had given so much of their time to help me out. They were gracious enough, after hearing about my mistake, to give me another long listening session, along with their invaluable input. All the comments on the sound of the No.26S in the text refer to it used in the correct manner (footnote 9)." Source |
#819 |
hahahahahaha Love it!! Yeah, maybe there is an improvement!? Maybe with the poor 75 ohm terminations, there's bit errors forcing the DAC's interpolation algorithm to kick in, thus improving the audio
Oh man, and don't get me started on AC cords
#820 | |
Really now? You best get right on the horn to Andrews, Cablewave and a hundred other manufacturers providing connectors for the RF industry with soldered centre pins. Over the last half century they seemed to have worked just dandy in transmission line applications as diverse as my 10 watt 2.2 GHz microwave hop and passing 300 watts at 98.3 MHz to my FM broadcast antenna. Let me know when the science starts guys. |
| Page generated in 0.21299 seconds (70.04% PHP - 29.96% MySQL) with 11 queries |
