#801 | |
Hear the real thing! |
#802 | ||
#803 |
the biggest con being bi-wiring or tri-wiring...
Bi amping maybe, but how can a wire split a signal.... in short it cant, all it does is ulitmately double the thickness of your cable and in some instances that might have an effect |
#804 | |
#805 | |
".........These go to eleven" |
#806 | |
http://sites.google.com/site/quasisdiyaudiosite/ |
#807 |
Why on earth would you have to match signal levels to compare interconnects? How could the fraction of an ohm in an interconnect cannot affect the level of a 22Kohm termination?
I don't use ABX testing. The best way to listen to wires is to plug them in and use them in the long term (hours at least). Long-term listening is more effective than an ABX test because it's closer to reality. ABX testing is an artificial construct and should not be used to replace the real deal. The real deal in this case being long-term listening in an intimately familiar environment (i.e. my system, my room, my music).
Dan |
#808 | ||
#809 |
They all laughed when I used 1/4" copper tubing with a liquid nitrogen flow to achieve near superconductivity....
#810 | ||
Cheers, John |
| Page generated in 0.22751 seconds (66.82% PHP - 33.18% MySQL) with 11 queries |
