#7691 |
#7692 | |
diyAudio Senior Member
Add some "Tweak"* to the contact area and that too should reduce contact resistance. *No idea if those little magic bottle are still on the market but that snake oil actually worked a treat. Cheers,
Frank |
#7693 | |
Banned
#7694 | |
Training also can make a big difference in a persons ability to use both of these mechanisms. All this plays a role in people being able to distinguish features that are often dismissed because "they are above the limit of human hearing" Turns out that is a much smaller time interval than previously thot. (ie <5uS) dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#7695 |
#7696 | |
Parts Express: Featured Categories |
#7697 |
One wonders what rubbing alcohol (isopropanol) does to oxide layers on interconnects? Simply unplugging and reconnecting an interconnect may remove "oxides", but isopropanol won't.
Gold plated interconnects are immune to oxidation (at least if the gold is more than a couple of microns thick, and has a nickel underlayer (most decent ones do)) since gold oxides are thermodynamically unstable wrt elemental gold. All the cramolin etc. contact enhancers do is prevent re-oxidation of contacts IF they are clean in the first place. To TRULY de-oxide a non precious metal surface (solder, nickel, chrome, silver, etc.) you need (usually) STRONG ACID solutions, and the deoxidized metal will only remain so for a very short time period unless protected by a subsequent layer of (wax, another metal, glue, plastic, pick your poison) As for the esoteric arguments re: dielectric loss/absorption, electron pools, single crystal topologies, micro-diodes, or simply I hear a difference so something must be different, unless some sort of reference is made to the degree of the effect, what's the point of discussion? No one will ever agree if some sort of metric is not applied, and the subjectivists ABHOR metrics. All those who bought a Sham Wow in the last month raise their hands... John L.
"...His brain is squirming like a toad..." Jim Morrison Last edited by auplater; 19th November 2009 at 08:35 PM. |
#7698 |
While 'objectivists' apparently can't wrap their heads around the concept of airborne pollutants not related to oxidization or, heaven forbid, that the listener might cook or smoke. One wonders what magic they believes transpires when they clean their inside windows. Oxidized glass?
Blame the Manichaeists |
#7699 |
For those of you who think that the audio crowd are the only ones who have trouble with DBTs, here is a good read.
![]() A Hint of Hype, A Taste of Illusion in the Wall Street Journal. .
Take the Speaker Voltage Test! |
#7700 |
Bob being the guy at "Snake Oyl R Us" that paints the arrows on.
Each day Bob sets himself down in front of a large box of cables, pulls them out one by one, paints on the arrows and tosses them back on the conveyor. Sometimes Bob screws up and paints arrows both ways on the same cable. Mr Oyl used to get mad at Bob when that happened. Then one day he realised he could just mark up the "rejects" an extra 30 percent and sell them as "special" bi-directional cables. Sales have been brisk. |
| Page generated in 0.23293 seconds (66.23% PHP - 33.77% MySQL) with 11 queries |
