#681 | |
diyAudio Senior Member
Whether the source is accurate or not, that's really not the point. Too late for acttion and out of reach anyway. For as long as you're not adding even more inaccuracies... Assuming that what you want is to faithfully amplify your "source" that is. No? Why would you need even more filters to accurately reproduce what's been filtered out already? Conversely, if you'd want to undo the initial filtering, how on earth would you know what's been filtered and how? Me no get it.... Cheers,
Frank |
#682 | |||||
Let me try again. All recordings made to date have been made while listening through some combination of "filters," from the microphones to the loudspeakers. Which means that the decisoins made in such recordings are based on those "filters." Which further means that as far as "accuracy" goes, the pits and grooves of the recording are meaningful only with respect to those "filters." Let me try an analogy. You hire a painter to paint a scene from the real world. His goal is to make the painting look as close as possible to the actual scene. However, he can only see his canvas through a filter. Let's say it's a funhouse mirror. So he paints the scene on his canvas while looking through the funhouse mirror and when looking through the funhouse mirror, the painting looks exactly like the real scene. But look at the canvas without looking through the funhouse mirror and you'll see something that's distorted with respect to the real scene. What I'm trying to get across is that the less-than-objectively-perfect recording equipment is the equivalent of the funhouse mirror. And further, most every recording out there as made using a somewhat different funhouse mirror. And finally, if you listen to these reocordings with an objectively perfect system, i.e. without the funhouse mirror, what you get is ultimately a distorted version of what was intended. So now let's take this back to your cable example. If a recording was made using say less neutral speaker cables, playing back that recording through more neutral speaker cables is ultimately a distortion in itself, all else being equal and if your goal is to reproduce the result intended by the one who made the recording in the first place. se |
#683 | |||||
If you don't add any inaccuracies, i.e. you use an objectively perfect system to reproduce the recording, the result you get is ultimately an inaccuracy in itself. If your reference is what was heard in the recording studio when the recording was made. Quote:
Just as the grooves on an LP contain the INVERSE of the filter in your phono preamp, to use a more literal example. Quote:
The only thing you do know is that there was filtering and that playing the recording back with an objectively perfect system will give you something other than what was intended. Quote:
![]() se |
#684 | |||||||
You can do your own "post-mastering" to your heart's content but then you're basically just "freewheeling". What would the basis for your adjustments be? Just do whatever you like? Without standards where do you end? Nihilism? Total chaos? Ah....Rock 'n Roll perhaps? Quote:
Either way, you'll still be needing some standard for that as well or you'll never stop fiddling with those knobs either. Quote:
Even the best recording equipment, ideal venue and/or ideal musicians etc. are likely to pass some kind of filtering before ending up being put on medium for the simple reason that it's not technically/economically possible to do otherwise. However_and that's MY point _I think it's wise to start out with a reproduction chain that at least CAN (technically speaking) reproduce that original recording correctly.If you want to tune the FR of your room for a certain deviation of the truth, use the loudness button all the time and boost the mids because you like it that way, then that's perfectly fine by me. It's just that I wouldn't rush to the hi-fi emporium downtown to buy myself a system that has that kind of treat by it's very nature. Would you? Quote:
The recording engineer's job (and for that matter the entire recording industry's) is to deliver us a picture of that event that's as realistic as is technically possible. *Modern "produced" recordings notwithstanding. Quote:
I'll say it again, there's little point in trying to undo the "funhouse mirror" for each and every recording: you have no way of knowing the lenses. Once you want to play that game you may want to buy yourself a tool a la Chello AudioPalette or something similar. Nonethelesss, even Mark Levinson would start with a clean Palette, not one with left-overs from yesterday's session, I suppose. What you seem to be proposing is even worse: you want to reuse the old colours over and over again and never clean the palette with terpentine. In fact, the palette and colours would be mixed right from the outset. Not a good place to start IMHO. Quote:
Something's either neutral or it isn't. Ask Switzerland. If a recording was made using those, say less neutral speaker cables (somewhat coloured?), playing back that recording through more neutral speaker cables (less coloured) is ultimately better than running the same stuff through the same colouration again, won't you say? So, using neutral gear, using neutral cables etc. is not going to colour the original more than it already was. What's the effect on FR of n identical slope filters cascaded, Steve? OR - + - = +? Cheers,
Frank |
#685 | ||
Frank |
#686 | |
For the record 2, I consider cables to make a difference in about the same degree salt does to a meal. Not overwhelming but significant with the potential for bad taste. Also, people (not you in particular) are too quick to give status the predominant role in cable preference: expensive cables are good because they cost a lot. In my case, the worse 'audiophile' cables I've ever used were very expensive van den Hull silver phono interconnects. Through multiple sysatem changes they never stayed in long. My favourites right now are home made tape-types using two strands of a heavier gauge version of the Litz from the test I described. I have no explanation why (the passive 'pre' likes the low low pF capacitance?) but there it is. Did I make 70? |
#687 | |
#688 | |||||||||||||||||||
My pleasure comes from many indefinable elements which together make up the gestalt of my experience. And not being a piece of objective test equipment but rather a subjective human being, my greatest pleasure doesn't always coincide with the most objectively accurate reproduction. Quote:
Typically it's the musician who creates the scene and the recording engineer who paints it. Quote:
Though even when minimalist recording techniques are used, I typically see the microphones placed where no ears are ever likely to be during the performance. Quote:
Which is why I think the end user should just create their own mirror which gives them the most pleasure at the end of the day. Quote:
Though really the main context here is cables and the like. Quote:
It represents the inverse of the filtering the person who made the recording listened through when making it. Quote:
You still don't seem to be getting the gist of this. If you're trying to make a recording that's as true to a live event as possible, and you're using a system which has certain inherent colorations, then you'll end up trying to compensate for the limitations of the system you're making the recording with. If the system is say a bit thin in the midrange, and you compensate for it by beefing up the midrange in the recording a bit, then what you get on the recording itself is a recording which would be too beefy in the midrange if it were played back on a system which wasn't thin in the midrange. In other words, the thin midrange of the recording system is a "filter" and after compenating for it, what ends up on the recording itself is the INVERSE of that "filter." Quote:
But as I've said, the recording itself is neither entirely true to the original event or the intent of the person making the recording. Quote:
It's what is the effect of your phono preamp's RIAA filter on the inverse RIAA filtering encoded on your LP? se |
#689 | |
se |
#690 | |
Carlos is right about his "filter" statement. What he and you don't get is that it is completely speculation, unfounded, to conclude that "because it is a filter, it is audible". As I said, hogwash. Maybe you should try to get your own basic thinking in order before thrying to speculate how other people do it. Jan Didden
/New Linear Audio publication: Baxandall & Self on Audio Power! |
| Page generated in 0.34086 seconds (75.71% PHP - 24.29% MySQL) with 11 queries |
