#6721 | |
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#6723 |
If any are female and hot, sure.
#6725 | ||
Blame the Manichaeists |
#6726 | |
diyAudio Senior Member
Now read Jimmy Hughes' tips (You know, that guy from Hi-Fi Answers) and see where you stand. What makes a difference and what doesn't? Rest assured, science will catch up. Cheers,
Frank |
#6727 |
Well!
The term "black background" was first heard by me some 20 years ago, but I recall to have experienced it way back longer. But here you both would be able to read about it, and if you try out some of these cables, you´ll also be able to experience it. Have a go for it. Taken from MIT´s homepage: Audio Interfaces MIT Cables’ mission has always been to help audiophiles experience the best sound they can by solving the problems inherent in standard wire. This mission began back in 1981 when Bruce Brisson designed the first purposefully built high-end audio cable: Interlink Reference, built by Monster Cable. It was the first audio cable in which everyone could hear the difference. All audio cables alter the signal that is passing through them because they act as inefficient low pass filters; that is to say they are inefficient at transporting power. How efficient or inefficient a cable is at any frequency within the audio bandwidth is what makes one manufacturers cable sound different than another’s. MIT goes beyond this. We start by engineering all of our speaker cables and interconnects with the best possible materials.. Then we add to them our patented Multipole Technology in parallel to the main conductors. These networks optimize the transportable power, at predetermined points (or Articulation Poles), throughout the audio bandwidth. The more articulation poles in the cable the better the cable will sound. When you connect an MIT cable up to your system, you will enjoy recorded music in an entirely new way. The background is black, increasing the contrast between the instruments and voices. A lifelike soundstage opens up with pinpoint imaging at any volume level. More than just cable: It’s not a saying. It’s what we do to help you experience recorded music in a completely new way. |
#6728 |
If MIT was as agressive as Harvard they would shut Bruce Brisson down. As it is I think he just labors under many levels of misconception. Their stuff has alway been, when examined objectively, of no merit.
Pain is never permanent |
#6729 |
Banned
#6730 | |
It fakes that "black background" and, when dialed in, you also get a very slight euphonic effect. Using only a slight amount of this (via its mixer), there's not much added distortion. Caveat: Any beneficial effect does not increase beyond the illustrated setting (rotate the dial till you first start to hear a change and then turn back just a bit--this may take several tries). The device is a capacitor based "passive buffer" and as the name implies, its Not very effective as a buffer, but it is under $5. This is a really cheap way to simulate a lot of spendy effects, such as custom caps, custom cables, tricks with preamps, and the like. Fortunately its an effects box that you can also turn off, much unlike spendy specialty items that are fixed in place.
| Page generated in 0.25498 seconds (67.39% PHP - 32.61% MySQL) with 11 queries |
