#6331 |
None of that keeps the dark matter out.
#6332 |
No worries I keep the dark matter on the other side of the baryonic picket fence.
Bud |
#6333 |
Could someone please tell me if KEY is serious. I went back a few pages and there are just too many pages, If he is then I will educate him in the principles of dark matter.
Terry
What we don't understand is called magic. |
#6334 |
I have a couple spools of the stuff bought surplus 20 years ago but never really found a way to use it well. Are you just doing individual cotton sleeves and twisted pair?
Ears aren't microphones. |
#6335 |
I think everyone should learn about dark matter either way shouldn't they?
#6336 | |
![]() Short cables should have less effect. |
#6337 | |
It think you miss the point in your quote above; Olive and Toole have found in there experiments that their listeners would change _rating_ and _ranking_ of two (quite) different loudspeaker models; and the difference between these models was above every hearing threshold. So it doesn´t matter if there is an really audible difference or not, listeners still will/can prefer the wrong alternative, if they are not able to deal with the different bias mechanism. Wishes P.S. Regarding the "wise phrase" if it doesn´t exist, may i suggest that you give me in the future the benefit of doubt that i don´t omit something for dishonest reasons? I normally just try to keep the post a bit shorter.
#6338 | |
If there's a sucker born every minute, where do the rest of them come from? |
#6339 |
#6340 | |
I thought you´ve made, under the assumption that this preference is based on frequency response alterations, the proposal to include a passive network targeting the frequency response instead to meet the _preference_ choice. Did i miss something? If the (short) description above is correct, isn´t that the same situation? Could the passive network approach work, if the listener isn´t able to deal with the different bias mechanism? Wishes |
