#6231 | |
BTW, all SATA cables are shielded, and there is no difference at all between SATA and SATA II cables, it's just marketing. |
#6232 | |
More generally, no design, whether single-driver, planar, dipole, horns, line array, or anything else, has a monopoly on their particular virtue - they just make it easier to attain a certain corner of audio heaven for a given amount of effort, but there is no reason that careful work with another type of design cannot reproduce those virtues. |
#6233 | |
just another
I suspect that linux (In my case fedora Core 10) probably pushes the hardware to the limit, where as Windoze is more conservative and hence will cope with sub standard hardware. As for SATA II, I generally refer to SATA cables with the latching mechanism (which was introduced before SATA II became more about marketing and was abandoned as the name for the standard) as SATA II cables. It is I believe more plugs that make the difference. You might note in my original post I used quotes around a lot of the terms like "special shielded" and "better" that is to emphasise the marketing overtone I've been working in IT for 24 years, and whilst I have certainly not built anywhere near the number of pc's you have with SATA cables, I have certainly probably had the covers off and fixed issues with probably close to that many over the years. from XT's right through to the current stuff In many cases the most bizarre faults were usually fixed by reseating a card or the chips on the motherboard (especially with the older gear). Back on topic: I was actually thinking that some of the more esoteric cables are probably much more likely to upset systems (I'm think about the amp here) than improve them. Cables with high capacitance or inductance due to their construction surely must be more likely to cause detrimental effects? Tony. |
#6234 | |
Banned
I have never heard of anyone trying to make their system sound worse, have you :-) |
#6235 |
diyAudio Chief Moderator
There must be a reminder about the distinction between the term adequate and better in audio practice in general. Where the right cable can be mistaken for better quality and the wrong cable can be dismissed as inferior.
Tony found the adequately better for his Linux box problem as it seems from the story. 2 in 1. |
#6236 | |
just another
It might not have been the intention, but in some cases probably was the result Tony. |
#6237 |
just another
I did a search on high capacitance cables and amplifiers and came across this video on youtube. The first thought was look at how the first cable is coiled up (and also the length) secondly the special cable is mostly out of view so could be very short in comparison. The fairly normal looking heavy duty speaker cable seems to put in a pretty good performance... also I'm not sure but the middle trace (difference between the two signals) seems to be thicker when testing the "special" cable, or am I just imagining it... In any case, if the cable does make a difference, the difference between it and the pretty standard heavy duty cable shown is pretty small, at 385 pounds for a 2M pair I'd say we were well into the territory of diminishing returns!
finally there is no mention of the levels involved. Good video for marketing purposes, doesn't stack up when looked at critically from a scientific point of view though IMO. Tony. Last edited by wintermute; 1st October 2009 at 01:46 PM. |
#6238 | |
Banned
People are looking for the small incremental differences that seem small at first, but if you take them away, it creates a real sense of loss. I never want to go backward. Again this will only happen if the new component makes the musical experience better in your system. Changes for changes sake are not always good. This takes a little time to determine. |
#6239 | |
You don't really need an exotic cable to upset theese amps.
Last edited by Panicos K; 1st October 2009 at 02:47 PM. Reason: additional comment |
#6240 | ||
If you can`t se the logic in this you should not post here at all. |
| Page generated in 0.25773 seconds (71.09% PHP - 28.91% MySQL) with 11 queries |
