#6081 | |
I was posting the 5 meaningful elements to picking an amp. I have no idea what audiophiles do...Im not one, never will be Im strictly an audio hobbies who will buy/build and test what I please. If you want to discuss, discuss if you want to fight put on gloves
#6082 |
Banned
It is easier to make fun of things of which you do not understand.
#6083 |
Can unconcious bias lead you not to hear differences or not buy a cable for example because you might not like the sellers face,the manufacturer,the fact that you have to spend more money and other similar?
#6084 | |
diyAudio Senior Member
Frank |
#6085 | |
I'm not looking for a fight, so let's look at reality. Suppose your golf pro analyzes your swing. He chooses the "correct clubs" based on said results. What happens when you try something that works better for you? How would you like it if your handicap improved and the pro dismissed you out of hand? John |
#6086 |
#6087 |
Banned
Bias is bias, no matter what the situation. In this respect both sides will simply go back and forth for ever. The two sides on this forum are forever split and I see no way to ever convene them. This will continue down the same path as all of the other pages with noting more gained than further bickering.
#6088 | |
I have done many swing analysis and any pro will tell you its never the clubs even if they are fitted. As handicap improvement is measureable, nothing posted by Curly Woods is measureable. Also the Pro would never question how you play better....Arnold Palmer had the worse swing in the game but he could flat out play. Mo Norman was one of the quirkest players period but he could hit a 2 foot spot from 200 years (Saw him do it). Audio is different, people are defensive for no reason. They refuse to accept there are things out there that will prove their beliefs wrong (people like me will change opinion any time there is proof, that is different then the Curly Woods of the world). It seems that only the critical listening crowd gets bent out of shape in every thread like this. I never understand their misplaced passion. Heck if it was me I would simply say "Yep, I know the science says there is no difference but I like Placebo and Im enjoying my setup" It should not really matter if someone like me posts "There isnt really an audible difference" and post some links to back up my opinion (Unlike the subjective crowd I look for secondary sources for more proof first). There would be zero debate if someone like Curl Woods would just realize that science is a little more advanced and a little more rigorous in its testing methods then someone like him. He should simply acknowedge that he is okay with BIAS and he enjoys his system. I wouldnt fault him at all, I would respect him for being intelligent but subjective. I use Audyssey but I do not like a flat response. I know its accurate but I still don't like it. I like using a Pro kit or a DCX to set my own curve. I realize this isnt what purest would do but Im not them. I enjoy what I do, what I have. I know pro audio amps are as good as high end amps but I still own a Sunfire for many different reasons (I also own about $5K in pro amps). Just learn, acknowledge and move on. You can be still extremely subjective after that. Last edited by doug20; 29th September 2009 at 07:19 PM. |
#6089 |
#6090 |
| Page generated in 0.21949 seconds (66.09% PHP - 33.91% MySQL) with 11 queries |
