#5981 |
frugal-phile(tm)
Well at least with no cable the noise floor would be really low -- no sound at all thou.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#5982 |
599 pages boys, i think it's time to reach some conclusions
#5983 | |
#5984 | |
John |
#5985 |
Almost not off topic.
Anybody here willing to spend $500 for two speaker cables and two bare full range Fe127en drivers? This rig, with the drivers in cardboard boxes, will provide you with more information, more correctly, than anything short of a full on floor standing Genesis system, and it will even do better mids than that. Wont go much below 80 Hz, with any authority, unless you splash for a real box with some resistive ports, and will not exhibit ANY of the audiophile beloved buzz words (slam, sizzle, bloom, etc.), but, you will find music, pure and bell clear, all the way to 90db down from the max signal level of 100 db possible. And all of this with no more than 20 watts of clean, well engineered power, from almost any class of amp you care to mate it with. Money back guarantee on this. Of course, you will have to return the items, undamaged, and pay for the freight both ways. However, the likely hood that you will even want to is very very low. Bud Last edited by BudP; 29th September 2009 at 05:00 AM. |
#5986 | |
#5987 | ||
frugal-phile(tm)
![]() Quote:
dave
#5988 | |
I might have been exaggerating with the length but I am sure there is some room to pull them apart - I have not dissected these yet but am planning on dissecting a cheaper brother when I get the time and money. I have seen a shot by shot dissection where the guy seemed to not like how "cheap" everything looked. they do sound great to me no matter how much fat they trimmed on these things. |
#5989 |
I have listened to tin foil and polyprop caps resonate along with bass notes. They added a serious gargle to the mid range they were conducting.
Ended up with them isolated in their own box, because, once I had been sensitized to the gargle, I could hear it even when the cross over was moved out of the enclosure. I doubt the 5 watt resistors were affected, but some poorly made hockey puck coils did come under suspicion and I replaced them with nonsaturable reactors, that had been vacuum varnished into obsidian like blocks. Bud |
#5990 |
There are some:
The best cable is no cable... as this is not possible, then use what you have at your hand. If you love to imagine things.. a creative mind..then use magic cables If you do not love to imagine things, not unobtanium addicted, them use simple cables or paralel wiring. Let them believe..this is human...let them say...you can listen without bother yourself. Cables has resistance, capacitance and inductance..nothing more. regards, Carlos
Drain issue already impeach me to be sitted soldering; http://www.youtube.com/watch?v=u8DGBc07eiQ |
| Page generated in 0.21512 seconds (67.13% PHP - 32.87% MySQL) with 11 queries |
