#5341 | ||
Ears aren't microphones. |
#5342 | |
No, why? Is it irony to ask why if some gives a sweeping statement: "If you can't hear the difference between A and B something is seriously wrong"? The arrogance, combined with ignorance, could certainly be reason for real irony. But then again, the poster probably didn't realize the extend of his post. Or do you have an issue with my statement that humans generally perform better under stress than the opposite? That can be easily looked up of course. Should I have given references? I thought this type of stuff is common knowledge, no? That people perform not very well wrt their capabilities if not challenged? jd
/Another new issue: Linear Audio Volume 3! |
#5343 | |
#5344 | ||
We are not talking about jumping over a 12ft fence with a lion hanging on your behind. |
#5345 | ||
Please read what the issue was. I was talking about DBT's, and the often heard - off hand, of course, don't ask for any background - statement that DBT's cause stress so that participants cannot hear subtle differences. That is in full contradiction to the well know phenomena that people generally perform better when under stress, not worse. And that is overwhelmingly documented. There's lots of people making a living from that phenomenon. Peace, jd
#5346 |
I would not go so far to state that stress always can lead to better performance - when it come to physical fight or flight reactions, that might be mostly true.
In the case of intellectual tasks however, folks have been know to "freeze" up during exams. Not that this is an argument against dbt, because reading the statements of participants - especially of some tests in germany that jacob usually considers not rigorous enough to withstand closer scrutiny - the "believers" proclaim that the test was "easy" and were quite confident of their abilities to differentiate up and until the results were made public, and the back paddling started in full force. Suddenly "stress test" was the rage, "unfamiliarity, though not of concern before the test was cited as an excuse, etc. etc. pp.pp. In short, everything was done to discredit a test to which everybody had signed on as to the methodology and evaluation, no ifs whens or buts. Why? because every single one of the mostly "believers" participating was so sure of himself to have the almost magical capacity. Only when shown that the magic was missing - then the whining and gnashing of teeth started. And that is why I do not take any of the cable mystics serious any more, and relegate them to the realm of the quasi religious. |
#5347 | |
Yes, that is why I used the therm 'generally people perform better etc'. You can overdo stress. But I agree with you that the automatic reaction 'ohh, DBT, the stress, I can't hear the subtle differences!' is nonsensical. In general jd
#5348 | ||
Yes, I am one of those that will openly say DBT's causes stress, especially if you are not used to it. That was (and sometimes still is) my experience, not something that I've read somewhere. Doing a test (not even talking about DBT) can easilly cause you to concentrate on the test and on 'finding differences' rather than relax and listen to the music. If you try to compare listening to music (allowing yourself to experience every detail) to sport, may explain our totally different perception of sound. |
#5349 | |
Ahhh but that's the point. NOBODY says that they sound the same. What is said is: "show me". Show me a repeatable, controlled test that shows they sound different and that's it. I know amps can sound different, I've heard it often myself. Was it repeatable and controlled? No. So I shut up. Andre, I make come across as angry but I am not. Only excited jd
#5350 |
[QUOTE]Originally posted by Andre Visser
[B][snip]Jan if you can't or don't want to see that I've said that trying to add a bit of humour, then I will remember not to make a joke with you again.[snip] Sorry, you're right. I'll lighten up ... jd
| Page generated in 0.23308 seconds (72.84% PHP - 27.16% MySQL) with 11 queries |
