Closed Thread
Old 5th December 2008, 01:39 PM   #2101
lineup is offline lineup  Sweden
lineup's Avatar
Originally posted by ShinOBIWAN
My old uncle Terry Deluckwit, swears by this stuff:
http://www.acoustic-revive.com/engli...psa100_01.html
Example of how to use on input and output terminal uses
It is easy to have a laugh on similar tricks, that people use to change their subjective perception of sound.
But how about changing one transistor, resistor, capacitor brand or other component?
If the effect we get is not measurable or otherwise verifiable
I can not see we need to laugh less or more about these positive effects.
And a subjective effect is one effect none the less.
But can only have limited use for a few persons
.. who actually can believe in this effect and so are open for to be effected.
Lineup
lineup
Old 5th December 2008, 01:50 PM   #2102
ShinOBIWAN's Avatar
[/B]
I see. Well I'm just off to my local spiritualist to get in touch with my long dead ancestors.
Old 5th December 2008, 02:42 PM   #2103
lineup's Avatar
if you believe in magic
there is nothing impossible to imagine ... like talk to my dead mama, once again
lineup
Old 5th December 2008, 02:54 PM   #2104
i never talk to my mama, although she is - presumably - still
alive. That's real magic guys !
Kind regards
Oliver, RFZ believer (?)
www.dipol-audio.de
Old 5th December 2008, 06:21 PM   #2105
thetubeguy1954's Avatar
Send a message via Yahoo to thetubeguy1954
[QUOTE]Originally posted by lineup
[B] And a subjective effect is one effect none the less.
But can only have limited use for a few persons ...who actually can believe in this effect and so are open for to be effected.
Lineup following that type of misconbobulated thinking, if a person had been born in outer-space on a spaceship with no gravity, and never taught about gravity then, when that spaceship landed back on earth, gravity should have no affect on that one person born in outerspace because one could state: [B] And gravitative effect is one effect none the less. But can only have limited use for a few persons ...who actually can believe in this effect and so are open for to be effected.
Of course that's a very extreme view but if you really believe in expectation bias ---{ because that's what you're describing ]--- is truly being the reason why subjective effects occur, then please explain why just the opposite of what I've been biased to expect to occur, has often been what actually occured!!! For Example I fully believed and was biased to expect not to hear a difference:
1) In 1m ICs and 3m speaker wires, yet differences I heard!
2) When applying CD treatments ---{like Auric Illuminator}--- yet differences I heard!
3) When using the VPI "Magic Brick," yet differences I heard!
Because if it's true that a subjective effect, can only effect those persons, who actually can believe in this effect and so are open for to be effected ---{as you essentially said}--- then the opposite is equally true and a subjective effect, cannot effect those persons, who actually don't believe in this effect and so are not open for to be effected!!! Yet the reality is just the opposite has occured on numerous occasions for me!
Thetubeguy1954
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society---Full-range/Wide-range Drivers---Front & Back-Loaded Horns.
Old 5th December 2008, 06:55 PM   #2106
analog_sa's Avatar
Originally posted by thetubeguy1954
a person had been born in outer-space on a spaceship with no gravity[/B]
This sounds like a description of Halojoy
Old 5th December 2008, 07:34 PM   #2107
SY's Avatar
That turns out not to be the case. Biases are often, maybe usually, unconscious. Humans are hard-wired to seek out patterns even when none exist- we can't help it, we can't remove our unconscious biases, thus the need for controlled sensory testing to take a claimed effect beyond the level of a fairy tale.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 5th December 2008, 08:58 PM   #2108
Hello Gentlemen,
though i love discussions with epistemological background,
i'd like to ask some pragmatical questions about things which
"are always done this way".
They have to do with the proximity of measurements to
"typical application" of components.
Is it near to typical application to measure the
frequency response of a speaker in an anechoic room
at 1m distance on axis ?
Is it near to typical application, to measure distortion
and other parameters of an amplifier using resistors as load ?
Is it near to typical application, to measure hifi equipment like
a tube amplifier or a turntable/tonearm/pickup standing on
a labor desk in the absence of vibration ?
... and so on
The typical application of HiFi components is - to me - to use
them for listening to all kinds of music we love to hear.
Kind regards
www.dipol-audio.de
Old 5th December 2008, 11:38 PM   #2109
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Originally posted by SY
There are certainly blind people doing molecular research. I've known a few of them.
Totally blind? Or just require special equipment to see?
Hear the real thing!
Old 6th December 2008, 12:54 PM   #2110
SY's Avatar
Totally. One of my classmates from grad school, for example, had retinitis pigmentosa which progressed to full blindness, but became a pretty prominent laser spectroscopist. I suppose he didn't have to worry about accidental eye damage...
Closed Thread
Page generated in 0.21558 seconds (70.93% PHP - 29.07% MySQL) with 11 queries
