#1871 | |
) ... and the blind person's experience is like having the camera shut off, which frees up some of the dsp's memory to read the mic input at higher sampling speed and resolution.
#1872 | |
#1873 | |||
Well heck, ya put that copper sleeve in, whaddya expect?? Nice design. Cheers, John |
#1874 | ||||
First arrivals* for a mono signal.. 1. left reaches left, right reaches right..image is centered. this is headphone as well as listening with a septum to prevent crosstalk. 2. Left reaches right, right reaches left..this is enough information for each ear to image the speakers directly (two), as well as a direction inverted imaging. Luckily, we tend to ignore the last three images, but I certainly agree they are confounders. My test uses the human "processer" to really duplicate as best as possible, the placement of an image. The goal in stereo is to pretend the speakers aren't there at all, so one should try to achieve that, no? Quote:
If one really is interested in comparing cables, human adjustment capability must certainly be considered, not ignored. Tinkering is entirely acceptable. But in itself, does not advance SOTA. When tinkering produces good results, the reasons MUST be investigated, analyzed, and reported. This was in essence, the "beef" I had with John Curl. However, I can certainly understand his attitude, as he makes a living in audio, and the better his edge, the better off he is..I cannot blame him.. Quote:
Using a synthetic, not found in nature stimulus for audibility is not a good thing.. Cheers, John |
#1875 | |
@ jneutron,
Not so much processing power needed so far it seems at a first glance. But our brain is able to do the same analyzing routine for numerous sound sources at the same time and for threedimensional spaces. So if we consider several instruments located in front of us but next to each other spanning for example 120 degress we are able to pinpoint to each source and if we add an instrument distance right in front of us our brain is still able to seperate this from the others and to tell us it´s right in front of us, but at a greater distance. And still listening in a reverberand space does enhance our ability to do so. Regarding additional test setups, suggested by you and KSTR, i´d have some doubts at least in the beginning. As we are holistic systems it is sometimes difficult to predict what our reactions to alterations will be. And the transferability of results to considerations about `normal listening`would become problematic. (The old rule of testing- the more controlled the less the practicability of the results) As the claim in our cable discussion is " it´s possible to hear differences after exchanging (for example) the interconnects" (all safeguarding included i.e. measurement, differences, hearing thresholds and so on) in a given setup, the first step has to be succesfull listening tests in _this_ setup. Everything else would be helpful in better analyzing and understanding of the underlying working principles later on, if the audibility is proved. Just for the discussion in the hifidelity reproduction scheme, in general the suggested experiments would be very interesting. |
#1876 | |||||
My points within the thread regarding audibility testing.. 1. How do we account for human ability to adapt transparently to a subtle change in localization parameters. 2. Why do we use synthetic artificial, not seen in nature signals to test what humans can detect? No ITD.. 3. Given purely synthetic stimulus to create an artificial source image, what level of changes are humans sensitive to specifically with respect to a real source. With the third speaker generating the real source, and two generating the artificial image, what artifacts within the artificial image system will alter the image w/r to the real one. 4. How tight do we have to control the artifacts of #3? Quote:
Assume one has created a test signal which can fool the subject into believing the center speaker (offset some arbitrary angle) is creating the sound. If we then rapidly switch between the derived image to the real speaker, will we notice an adaptation time constant? If we use simple panning to derive the virtual image, is adaptation the same time constant? If we drop in some ITD, then pan that to get the virtual, is the adaptation the same, different, no change. If we find the correct mix of ITD and IID to eliminate any adaptation, THEN we use that mix and the CUT (cables under test) to determine if the cables cause the systems to diverge. Cheers, John |
#1877 | |
Banned
Gentlemen?? Your cable measurements please??? Lock the thread? Uncomfortable with the discussion Andy? How about not reading it and allowing those who wish to discuss to continue? Is anyone forcing you to listen to the blasphemy of the heretics? cheers, AJ |
#1878 | |
What are the chances of finding two different cables with the same LCR measurements anyway? Then wire diameter is also important, in the end every cable is a compromise. André |
#1879 | |
cheers |
#1880 |
DOUBLE BLIND TEST RESULTS ************************** Ok guys, I've just done the DBT. 2 ICs used, 1 copper (VdH D102III), 1 silver (Glasshouse kit 1) Randomisation by coin toss, test run by my 13yr old daughter across 3 rooms (one listening room, one waiting room for me, another for her) - ie we did not see each other at any point during the test. Amp volume same throughout. System as sig. Music: studio recorded pop - Lenny Kravitz, listening for: Overall clarity, freq balance, guitar harmonic structure, sibilance, percussion dynamics, mid-bass tone and evenness. 20 tests, same part of same two tracks each time. I attempted to identify each cable. RESULTS Null hypothesis = 10/20 Test cables correctly identified = 5/20. (On tests: 5,7,17,18,19) So rather muddy water - I expected either a null or a positive result. If analysed as identifying audible DIFFERENCES between cables then it was statistically significant (two tailed p=0.0414) ie this was not a chance result. But if looked at as an audiophile identifying silver/copper differences with confidence then it was a failure. I thought I could hear the generally described differences attributed to silver (lean but extended bass, slightly raised treble, smooth but detailed highs). I can't. I consistently mis-identified the cables. Not randomly but wrongly. Interesting - and irritating!
FLAC, Ethernet over Mains, SB3, GD Audio DAC 19, Tubelab SE 45, FE206eN in Scotmoose Sachikos with Fostex FT17h supertweeters 0.68uF cap.
| Page generated in 0.26833 seconds (71.62% PHP - 28.38% MySQL) with 11 queries |
