#1501 |
Oh, and don't forget guys...
If one uses either a single driver or a two way system, one has to take into account the physical location of the woofer, especially if it reproduces any of the signal of interest. 2 uSec of ITD is shall we say, incredibly small? Sound travels 1137 feet per second at 25 C..13,644 inches per second. 73 microseconds per inch. 2 uSec is 2/73 inches, or 27 mils, .027 inches. If the woofer is moving this much, it is dithering the arrival time of any higher frequency signal it is reproducing.. I don't know about anybody else, but I typically move the woofers a tad more than that..otherwise, where's the fun?... Cheers, John |
#1502 | |
The relevance of spatial hearing with respect to audible cable differences seems very limited to me. |
#1503 | |
I'm going to try and explain my audio POV to you. First and foremost my choice in audio equipment is based on my subjective opinion of what live, unamplified music sounds like. I attend symphonies, and as many outdoor concerts as I can ---{both unamplified & amplified}--- I also play acoustic guitar. My choices are made in this order; 1) cost, 2) sound quality and finally 3) visual appeal. Although I have a fairly expensive audio rig ---{Mastersound Reference 845 integrated SET, BlueNote Stibbert CDP, Aliante Pinafarina One speakers, Nordost BlueHeaven speakerwire, Stealth Audio M-21 Super Powercords and I've recently replaced $1800 ICs with a friends DIY, cheap and ugly ICs that sound better than any other IC I've ever heard}--- I actually listen via low-fi most of the time, which consists of music from my car's CDP 1 hour to and from work and 8-9 hours a day via a small transistor radio at work. For me it's the music first and foremost! However at home I want the best best possible replication of live, unamplified music I can afford. Once I've "proven" something to myself ---{such as there are sonic differences in wires}--- I'm content that it's true and really don't care what the reasons are that might cause these audible differences! I'm not seeking neutrality or accuracy as an objectivist would define it. As far as I'm concerned my SET is more accurate than most solid state amps, NOT because it measures more accurately but, because it sounds more like what my subjective opinion tells me is an accurate replication of live, unamplified music! I'm more interested in a listening experience I can enjoy, than proving I can hear differences or even understand why these sonic differences exist in the first place. That doesn't mean I have no interest in how something might work, or whether it really works or is imagined. Whether a device actually works as described or whether it's a placebo, doesn't really matter as long as it leads to a more enjoyable listening experience. I believe wires and audio components sound different ---{not always, yet sometimes dramatically}--- and I believe that sometimes my ears are fooled ---{actually everytime I hear a soundstage, my ears have been fooled}--- the thing is this is a hobby and it's supposed to be fun, not work! For me and I believe most subjectivists, it is fun. Sadly I cannot say it seems that way for most objectivists. To me it seems that objectivists get more pleasure from attempting to prove subjectivists are wrong than they do from listening to their audio systems.
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society---Full-range/Wide-range Drivers---Front & Back-Loaded Horns.
#1504 | |
Hoewever, to conclude that a difference between two signals is audible and of practical use, the difference must be audible in the original signal. If a difference is masked by the original music, it is not relevant. Interesting would be to investigate if audiophiles are more influenced by the knowledge of the existence of masked differences than other people. Information about the system certainly has a psychological effect while listening to music. |
#1505 | ||
But yet, humans do it without computation, all the time. How do we correlate what a reproduction system can do with respect to image stability and placement if we cannot measure it? As you stated, we calculate it. So given that, where are the calculations? Who has even defined the problem?? Quote:
Well, that's one approach. But that is certainly not universal. I have pointed out but a few confounders to the accurate reproduction of a spatial image, and these are the trivially easy ones. Imagine the difficult ones.. Cheers, John |
#1506 | |||
I didn't find a single word about the influence of cables. Quote:
The illusion of spatial sound imagery is what Philips used to build in their gettoblasters in the eighties and nineties
#1507 |
@ ravon,
yes a valid listening test is the way it should be done. Accompanied by proper measurements to assure that every piece is working as intended. |
#1508 | |||||
But yet, some will claim that rudimentary measurements (which is current SOTA) is sufficient to determine all the parametrics that the neural computer we are born with uses to determine spacial imaging. Silly things like single channel uncorrelated spectral analysis..pffft. Quote:
Nor, solid state vs tubes, nor even something as simple as the assymetrical AC transfer function caused by an overhung voice coil. None of those are within their statement of work, not their concern. They've laid the foundation of understanding which guys like US should apply to the task at hand.. Nice link, lots of stuff I knew, but plenty of things to learn as well..twill keep me busy... Quote:
What is the recording? It is two channels of amplitude only, with image placement governed by simple IID...no ITD? And in reproducing the recording, should we ignore effects which can alter some of the recording delay 2 uSec and some small intensity difference, say .2 dB? Honestly, I ignore any and all interchannel effects when I play my system...but it is not so important to me. But others consider image placement of interest to them.. Quote:
Cheers, John |
#1509 | |
#1510 | ||
Banned
Is it classified top secret information, where you would have to kill us after telling us? (There is no shame in admitting "Don't really know but still believe") Quote:
cheers, AJ |
| Page generated in 0.28909 seconds (72.40% PHP - 27.60% MySQL) with 11 queries |
