#131 | ||||
I said that in the context of losing a bit of wire diameter due to some of the copper atoms at the surface having combined with oxygen, resulting in an effectively smaller (though only microscopically smaller) wire diameter. Quote:
The greater transport current density nearer the surface of the conductor (skin effect) isn't the result of the electrons all migrating toward the surface (i.e. not penetrating the depth of the conductor). It's because more of the electrons toward the center of the conductor are tied up spinning around in eddy currents and not contributing to transport current. So as I said, there are electrons throughout the conductor. Just that as you get toward the center of the conductor, fewer of the electrons there are contributing the transport current. Quote:
"Current bunching" is more commonly known as "proximity effect." Its cause is the same as for skin effect. Eddy currents induced by time-varying magnetic fields. The two effects (skin effect and proximity effect) are basically one and the same. Skin effect is from the perspective of a single conductor and priximity effect is from the perspective of multiple conductors in close proximity to each other. But so what? The copper oxide on the surface of the wire isn't participating to any degree in terms of conduction and transport curent anyway so what exactly is the problem? se |
#132 | |
Yeah, can't get much more direct than that. Acoustical to mechcanical and back to acoustical. Like Lars used to say, "Look! No watts per channel!" ![]() Well, no electrical watts anyway. se |
#133 | |||
diyAudio Senior Member
If you care to wrestle through Dr. Malcolm Hawfords work you'll notice alot of what most cable manufacturers do is based on that. So, assuming I read you correctly we could all expect a range of cable from you that can be as oxidized as possibly imaginable? You're probably going for a PVC or other chloride rich insulator since that doesn't matter anymore either... I wonder what geometry you'll adopt but I'm sure that with sufficient marketing clout and appropriate amounts of hype they're going to beat the hell out of all competitors, right? BTW, some vulgarised resume of Dr.Hawkfords work was published in Hi-Fi News back in 1988 already under the title "The Essex Echo". Quote:
So, would it be safe to conclude that you don't think crystal boundary effects, contaminants and whatever else is out there is just a load of salestalk? Cheers,
Frank |
#134 | |||||
But I would like to think that even here most would expect that which is being presented as factual actually be factual and that those things which are presented as factual should be open to questioning. Quote:
What I have said is that that which has not been scientifically proven should not be passed off as fact. To do so is just as irrational and misleading as saying that that which has not been scientifically proven must therefore be false. And just as irrational as your PRESUMPTION that because I say something hasn't been scientifically proven that I am saying it must be false. Quote:
But where was all this logic and reason you exemplify above when you judged me based not on anything I've actually said, but on your own presumptions? Isn't that the very definition of prejudice? Quote:
se |
#135 | ||||||
And cable manufacturers were addressing skin effect before Hawksford wrote the Essex Echo series in HFN&RR. And while it's been quite a few years since I read that series, I don't recall Hawksford claiming that there is a dearth of electrons in the center of the conductor. Quote:
But suffice to say that in situations where I don't actually need any insulation on the wire, I don't use any. It's a bit difficult though to make interconnects and speaker cables without any insulation. Quote:
Why would he leave such a piece of work to be published only in a consumer audio magazine? Quote:
se |
#136 | |
se |
#137 | ||||||||||
Yours is going to be highly capacitive though. Like anything else, it's a compromise. Quote:
After all skin effect is nothing new, although maybe new to you... RF engineers countered it quite nicely by using hollow conductors around WW2. Quote:
Not that I believe everything I read, far from it............. So, if you don't mind me asking, where is it you want all of this to go? Cheers,
Frank |
#138 |
Hollow conductors? Like copper pipe, perhaps? (silver pipe if you're picky?) Would this work well as an audio conductor?
I picked up a copy of Audiophile magazine a while back and read a few articles, including a comparison of 4 cables that were, if I remember, 3m long each... or some shortish length... anyway, they were all >$450 per, and, AFAICT, just different combinations of insulations and ends... It seemed to me, that selection of driver materials, crossover frequencies, and box design would make orders of magnitude more difference than the cable... I also thought it was interesting that there was no AB or ABX testing in the article; they just plugged in one, listened, then the next, listened, perhaps did some back and forth, but did nothing to even address placebo effect. I guess it just bothered me that people who spend so much time and money tweaking every last part of their stereo systems, are unwilling to accept any scientific testing at all. If it were me with the $100K setup, I'm sure it would rack my brain to no end that perhaps I was wrong in my selection of cable A over cable B, or the amp, or the CD player, DAC, or box design. Doesn't that eat away at anyone else? Could I take this as proof that it really is just a money thing, and there isn't any difference of any importance between my $0.50 cables and your $500 cables? *sigh* Why did I ever subscribe to this thread?!? *unsubscribes* |
#139 | |||
Fashionable variations on the theme nowadays are foil conductors and oval conductors... And yes, they claim to have invented the wheel... A hollow conductor does all of that and more... Quote:
Little do they know, but can you blame them?
Frank |
#140 | |
| Page generated in 0.26102 seconds (73.62% PHP - 26.38% MySQL) with 11 queries |
