#12071 | |
To me, the positive control needs to be a cable/device that exhibits the kind of response proponents of cable sound promote (minute changes in timbre, difference in imaging, improvements in micro-details, that sort of thing) in a measurable and controlled manner that can be quantified. Your proposed "positive control" does not address any of these at all John L.
"...His brain is squirming like a toad..." Jim Morrison |
#12072 | |
![]() But, he also wrote about the relay ´click sound´, but that was detected by Vanderkoy: "I expressed my desire to try the test, and Remington went to cue up the record again, but I requested to be allowed to undertake the test with no signal passing though the system. Before realizing the import of what he was saying, Vanderkooy interjected: "Ah! You're going to listen to the sound of the relays." Yes, there is indeed a slight audible difference between the acoustic "click" made when the "A" and "B" relays pull in. This is due to the unavoidable differences in the mounting positions of the relay on the A/B/X box chassis and, although slight, it can be heard if one listens for it. I replied that I was going to listen to the difference in background hiss, and the subsequent series of blind trials showed conclusively that the two signal paths could be reliably distinguished on this basis alone." quoted from: Boston Audio Society - ABX Testing article Wishes |
#12073 |
But again, you evaded the issue of an appropriate positive control. The claim, for the 10,000,000th time is, "I can hear a difference between wires/cables/interconnects/whatever that is NOT due to mundane factors." Now, what is an appropriate positive control for a wire test, something in wires unrelated to the mundane variables, that has an established threshold?
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache |
#12074 | |
What you quoted above as response proponents can be subsumed as sound differences and of course reported are a full bag of other possible differences (like faster, clearer, more dull, exaggerated bass and so on), and that is exactly what the positive controls proposed will deliver. Please remember that level differences that small will be percepted as sound differences; on the mentioned list from Paul Frindle´s paper you will find audible distorstion as low as -80dB, level differences as small as 0.05dB. Or take for example the difference between an old philips cd player and third generation sony cd-player mentioned on the abx web site. Normally a difference between two different devices will be described with respect to differences in the "sonic signature" of each device. But of course other controls are thinkable, but there some requirements that must be fullfilled. Wishes |
#12075 | |
While an objectivist primarily embraces science, measurements or specs. Objectivists claim their methods are scientifically oriented. A objectivist allows a DBT to be the final judge. Thus it's the very science and objectivity they embrace that demands the DBTs be criticized if not done properly! Thetubeguy1954 ~Rational Subjectivism. It's An Acquired Taste!~
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society---Full-range/Wide-range Drivers---Front & Back-Loaded Horns.
#12076 | |
Why the insistance of having unknown variable added i.e., an ABX box? This ABX box is never part of anyone's home audio system! The wires ---{which are the device actually being tested}--- can easily be manuelly switched without providing any Clever Hans clues provided proper protocols are followed! I know, I know, not adding an unknown variable and only testing the wires... it's just not fair, right?? Thetubeguy1954 ~Rational Subjectivism. It's An Acquired Taste!~
#12077 | |
No test done improperly is worth reviewing whether done by a subjectivist or and objectivist. The objectivist must hold himself to the same standards that he requires of others. It's the subjectivist that does not seem to have that requirement. |
#12078 | |
Personally I'm beginning to think now that someone has stepped up and accepted the challange to prove they can hear a difference in wires, you "supposedly" objective, scientifically oriented, measurements & specs guys are getting nervous. You all know from the very beginning one of my stipulations was the wires be manuely switched sans an ABX box. This new almost insistance about the ABX box being added is a good way of trying to sabotage the the coming DBT and prevent the "truth" (whatever that may be) from coming out! Thetubeguy1954 ~Rational Subjectivism. It's An Acquired Taste!~
#12079 | |
Furthermore it seems to exist a general unwillingness to replicate tests done by others to see if the results were reliable. Therefore quite often newer test results were in contradiction to older studies but no one ever tries to find explanation for that. Otoh every designer has his own working hypothesis and wouldn´t be able to work if he could only evolve his product by using double blind tests. And if double blind test will not help to raise the sales figures of any product, than it is questionable if someone will pay for extensive tests. Wishes |
#12080 |
@ thetubeguy1954,
that is simply a misunderstanding; our ongoing discussion about ABX switch boxes and their possible influence is in no way related to your test with SY. ![]() In this thread we are dealing with a whole bunch of topics in different states of discussion. Wishes |
| Page generated in 0.27135 seconds (72.68% PHP - 27.32% MySQL) with 11 queries |
