#11891 |
Ah, but Madoff needed the 1/2 share jet to hip hop to his yacht in Antibes.
Apparantly they're still having a bit of trouble with the private sale of Bernie's 88ft Italian screamer at higher than scavenger level. One's incarceration is another's animation, as Bybees.
Looks like Sponge Bob has killed another thread. Last edited by jacco vermeulen; 9th February 2010 at 01:18 PM. |
#11892 | ||||
The Fostex FE206ES-R drivers I use are also a "custom" driver because Fostex released it as an improved, limited edition, version of their FE206E driver and it is a "custom" driver because of my having it modified with Mike Rispoli's proprietary cone treatment! So it's a one of a kind! Quote:
Now that that's done I'll be ready to try listening to different wires. One of my friends from the Central Florida Audio Society dropped off a PC for me to repair last night. He'll be coming over Friday or Saturday to pick it up. When he does we'll do some wire swapping. Quote:
I cannot tell you how many members of Central Florida Audio Society, Space Coast Florida Audio Society & SETriodes group want to attend this event too! So it's not that I don't want you to attend the DBT it's simply a matter of deciding who the remaining 1-3 people should be. I'd like a balance of proponents and opponents of the wire issue to attend. Most likely, although it's not set in stone, you'd have to come a little before or after ---{that will be your choice if you're not selectd to be one of the last 1-3 positions left} Thetubeguy1954 ~Rational Subjectivism. It's An Acquired Taste!~
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society---Full-range/Wide-range Drivers---Front & Back-Loaded Horns.
#11893 |
I would need one other person to do the switching (not a fun job, he can't have any contact with any of us during the test but could certainly join us for drinks and a post-mortem afterward), but beyond that, it's up to you- whatever makes you the most comfortable and confident.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#11894 | |
Thumps up for you though!
"Convictions are more dangerous enemies of truth than lies" - Friedrich Nietzsche Cardioid-like + Waveguide 2-way |
#11895 |
Pausim, you have it right. When working at the edge of knowledge of a subject, areas not described in normal textbooks of the subject, or in many practical applications, it is not possible to 'prove' everything that you find 'works' to the satisfaction of everyone.
While today, over 150 years later, Dr. Semmelweis is appreciated for his discovery, it was NOT true at the time, EVEN with the evidence that he had gathered. It is the same in audio, today. To be really successful, or at least ahead of the pack that includes companies with resources far beyond what we can ever have, we have to keep our eyes open for both practical improvements, that might first appear as only 'accidents' and yet apply every new idea proposed by others, and even older ideas not usually associated with audio. Quantum physics is one of those areas that is often useful for understanding how to make better audio equipment. It is NOT my area of expertise. However, I find that using a concept derived from what I can understand and use of it, gives enough intellectual framework to go along with it. |
#11896 | |
Do you really believe that?
Pain is never permanent |
#11897 |
It would be nice to have some real discussions on cables, differing constructions, materials etc and how these change the well known and well documented variables that effect signal transmission, (mainly L C R G, and dielectric effects), and also their effectiveness or lack of in regards to EMC, also how they might interact with varying input and output impedances of the connected equipement.
It would also be of benefit to ourselves and others to prove or disprove some of the more eclectic myths regarding signal transmission in cables at Audio frequencies such as Skin Effect, micro diodes (ha!), directionality of copper with ac signals(with reference to signal transmission, not the end at which the shield is connected). We are dealing with wavelengths of approx 15,000,000m to 15,000m with relatively slow rise times so there shouldn’t be the same problems as high speed digital suffers with reflections, ringing etc over what is a short run of cable compared to the wavelength (i.e. not really transmission lines as defined today for high speed design) |
#11898 |
Scott, why would I NOT believe it? What have you done lately, to help audio get more refined? Hanging out with analog designers of similar feelings on the subject? '-)
#11899 | |
You might have designed some amps that found their way into audio products by the 100k's, but what have you REALLY done ? ![]() jd
/New Linear Audio publication: Baxandall & Self on Audio Power! |
#11900 |
No, actually the guy's from ESS insisted that the difference in DAC's is "black and white" (as if I haven't heard that before). I will take them up on a personal demo. Kirkwood promised me some PFET samples too.
| Page generated in 0.23949 seconds (68.07% PHP - 31.93% MySQL) with 11 queries |
