#11871 |
Actually we had concepts for the other way around, for example a good conductor on the inside like silver, then copper, then gold. I came up with the name GPS for Gold Plated Silver also the name for the european positining system.
#11872 |
the idea of that cable was to keep in inside more conducting then the outside. I kind of backwards thinking on the skinn effect.
#11873 |
the name for gold-silver alloy in german is "Elektrum". Under certain conditions it is more conductive then silver. As far as i understand the rationate pure silver with no contamination is not posible to make. The gold then fills in the otherwise poluted aereas. Very esoteric and expesive, don´t you think! Invest in my new cable company and success is guarantied in asia !
#11874 |
Joachim, please READ UP, before putting me in a bad spot. Almost anyone here can at least TRY to learn something new, before dismissing it. I gave a specific book and page numbers. The book is published by Springer-Verlag, and is one of dozens that I have that are in general, outside my normal 'need to know' in electronic engineering. In this case 2 specific alloys were specified: AuCu and Cu(3)Au. These specific alloys show a significantly lower resistivity than other proportions of any Au Cu alloy mixtures. There is a graph showing this to be so. Why, does this happen? Could it be useful? I only brought it up, because that is where my interests lie, not in trying to see if I can get away with something almost acceptable from the hardware store.
#11875 | |
Banned
![]() How are we to ever sort out these mystic (audible??) cable properties, if you are always distracted? Is this why we still have no data, but instead references to "Jack Bybee" or "pg 88"? The relevance to the audibility of cables is.....??? |
#11876 |
#11877 |
It is NOT the resistivity, per se, but the radical change in resistivity with various proportions. The mechanism may have a secondary attribute.
#11878 |
Thank you, however, for showing the graph.
#11879 |
Maybe low resistivity is not the only factor that makes good sound. Some of us subjectivists prefer copper to silver. In cartridge making it is a matter of fact that cartridge designers use different materials to "tune" the sound of their products. In the perfect world tuningis of cause bad but to this day i have to hear the "perfect" system.
Perfect recording, perfect listening room etc. What is hard to argue that many times you have to intruduce a "mistake" to make a system sound well under the circumstances. What makes we really woried here is the growing gap between "theoretists" and practinioners in the field. |
#11880 |
| Page generated in 0.21422 seconds (64.60% PHP - 35.40% MySQL) with 11 queries |
