#11851 | |
Would something be determined if others begin posting about how nice my speakers sound and disparaged how multi-way designs sound in comparison to them at a GTG here like you just did for Terry's speakers? Would this disagreement somehow be settled or won if either Terry or I have the most posts saying our type of design sounds better than the other's? When will people learn every speaker design has it's own unique sets of pluses and minuses? If any of the different types of speaker designs be they, multi-driver, electrostatic, single fullrange, planar-magnetic, horn or ribbon, was the best we'd all hear it sounded best and we'd all be using that design. Why do you think there are people who swear electrostatics are best at replicating music, while another will swear only a multi-way all horn system makes music. Still others swear only an all ribbon speaker will sound like real music. Then there's people who swear there's a best type of speaker at every spectrum and only a ribbon/electrostatic/dynamic driver based speaker will really make music. Still others swear by single fullrange drivers as the way to replicate music. Finally I'll ask the real question that needs to be asked, what was the intended purpose of your post and what the heck does any of this have to do with providing any input on cables and whether or not they make a difference? You know the actual topic of this thread... Thetubeguy1954 ~Rational Subjectivism. It's An Acquired Taste!~
Central Florida Audio Society--SETriodes Group--Space Coast Audio Society---Full-range/Wide-range Drivers---Front & Back-Loaded Horns.
#11852 | |
here's a hint. It wouldn't remain a "monocrystal" for very long.
"...His brain is squirming like a toad..." Jim Morrison |
#11853 |
Nobody has ever said that you should abuse a 'monocrystal' cable by excessively bending it. In fact, VDH warned me decades ago that I could no longer twist my power supply wires with an electric drill, as I had been taught to do in industry. That puts us about 20-30 years ahead of your research on wires.
#11854 | |
When twisting is done right (i.e. on a machine using spools or bobbins such that the spools or bobbins turn as the wire is twisted), the wire is only bent. When you use a drill, it twists the wire and the insulation. se |
#11855 |
AMPEX Research Division.
#11856 |
#11857 | |
never did that vacancy calculation, did you?
"...His brain is squirming like a toad..." Jim Morrison Last edited by auplater; 8th February 2010 at 10:22 AM. |
#11858 |
Seems to be news, here. But not to real wire designers. You see, we have addressed these problems and have even gone beyond, using isomorphic designs in several cases, for this very reason.
When it comes to vacancy, I am glad that you brought the subject up. While unavoidable completely, it would appear that you get less vacancies, with: material purity, and proper annealing. Lowering resistance proves this. |
#11859 | |
The NS's are ruthlessly revealing, you'd definately know you were listening to a class B or AB amp due to the NS's tweeter which is pistonic up to 27Khz. Funny that top manufacturers (Focal JM lab, Paradigm etc) have only cottoned onto Beryllium as a driver material in the last 5 or so years when Yamaha where using it in the late 70s.Yes i'd suggest that given the opportunity you get to listen to a pair on the valve poweramp of yours, i'm sure you'd be pleasantly surprised.. Back to the wires, sorry ![]() Mark.
"Never let your morals prevent you from doing what is right!" Salvor Hardin |
#11860 | |
Nominal 10 gauge annealed type 102 copper (wire copper) would yield at a few tens #'s stress, not hard at all to achieve in normal use. pretty limp stuff. Ever here of work hardening? Can't figure out the calculation, eh? Thought so.
| Page generated in 0.24360 seconds (70.85% PHP - 29.15% MySQL) with 11 queries |
