Closed Thread
Old 15th May 2008, 01:44 PM   #1121
Originally posted by AJinFLA
Be not jealous, for jealousy lead to hate....and we know what hate leads to.
AJ
Yes we know, constipated little chimps.
Old 15th May 2008, 02:46 PM   #1122
Originally posted by nunayafb
It would be easier to believe this test occurred if you provided the test parameters.
Sorry, missed this part.
I've listened to the four different cables, playing my favourite test track, knowing which cable is used. Then I left the room and a friend and the cable importer would randomly insert a set of cables, then I go back in to listen and could name which cable is playing. This was repeated 12 times.
Yes they have covered everything so that I could not see what was used
Old 16th May 2008, 12:50 AM   #1123
Sorry dude, but I don't believe you....
All we have is your word that all of these electrically equivalent cables sound different, and that you didn't see them, or that this test occurred and you didn't just go to a website and pick 4 cables!
But I am willing to play along.
I feel confident in saying that if you heard a difference it should be measurable. If it is measurable then those are crappy cables. But being that they all use high quality conductors and shielding- I would bet these all perform the same.
Cables allow voltage to pass from A to B, they have a DCR and frequency dependent impedance and noise rejection. Quality cables have low DCR, flat impedance curve (in audio band) and shielded enough to keep noise out (if you routed them poorly).
Thats it, there is no magic! Speakers convert the voltage they receive to sound-there is no spiritual musical aura that is passed through the many useless layer of "high end" audio cables. It is just voltage.
Conventional methods yield conventional results
Old 16th May 2008, 05:03 AM   #1124
KBK is offline KBK  Canada
If you guys think these arguments about cables are bad now..they are going to get considerably worse in the next while. Hang on to your hats. Enjoy the debate. 'iffin you can.
"Never forget that only dead fish swim with the stream." -- Malcolm Muggeridge.
"Truth cannot be brought down, rather the individual must make the effort to ascend to it." -- Jiddu Krishnamurti
Old 16th May 2008, 05:43 AM   #1125
Brett's Avatar
Any particular reason why?
Old 16th May 2008, 07:08 AM   #1126
BudP is offline BudP  United States
BudP's Avatar
Maybe I should start an EnABL cable war. Could be almost as much fun as the original!
Bud
Old 16th May 2008, 07:13 AM   #1127
Oh, they likely will. Is all. Carry on, all is goodness, etc.
Old 16th May 2008, 08:42 AM   #1128
Alan Hope's Avatar
All we have is your word ... etc
You know, there is major psychology going on on the "objectivist" side of this debate. If you start with the preconception that scientifically all cables must sound the same, and simply refuse to even begin to consider claims otherwise then you have a psychologically entrenched position.
I retain a foot in each camp. I hear burn-in changes, but the nature of what I hear suggests a significant influence of psychology. It is clear from posts like the above that should I try to double-blind my cable listening I will simply be disbelieved if I can differentiate cables.
One of our "objectivist" posters claimed that he would only accept non-tweak things, and his list included speaker-height. Well can I challenge him - listen blinded to your speakers at normal height, then again 2 feet higher. Can you identify which is which 100% of the time. I'm willing to bet it would be pretty close to 50:50. Therefore - to apply the logic that started this thread - scientifically the auditory effects of speaker height MUST be entirely psychological. And anybody who ever says otherwise is deluded and to be pitied.
But then entrenched positions are so easy to hold, and feel so reassuringly strong - don't they?
FLAC, Ethernet over Mains, SB3, GD Audio DAC 19, Tubelab SE 45, FE206eN in Scotmoose Sachikos with Fostex FT17h supertweeters 0.68uF cap.
Old 16th May 2008, 11:59 AM   #1129
SY's Avatar
Straw man.
The problem with "considering a claim" is that the claim has to actually have some evidence for it to be considered. Cable-sound evidence, to date, has been demonstrated and no-one disbelieves it. What has NOT been backed with any evidence whatever is that factors beyond the gross effects of LCR on frequency response and stability have any significance.
All it takes is... evidence. Not stories. Not unsubstantiated claims. Not anecdotes. Evidence.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 16th May 2008, 12:08 PM   #1130
MartinQ is offline MartinQ  Canada
Changes in speaker height can be measured in the acoustic response. Your listening angle and distance changes as well as the relation to the rooms boundaries (modes, reflections, etc.)
Changes in similar cables cannot be measured. Similar being in length and LCR values.
Closed Thread
Page generated in 0.22554 seconds (68.43% PHP - 31.57% MySQL) with 11 queries
