#1111 | |
Ears aren't microphones. |
#1112 |
diyAudio Chief Moderator
Cables, capacitors, tubes, transformers, resistors, transistors, screws, boxes, all do sound different. That is one of the reasons why there is still a hobby! ABX as much as you like. If you cant listen to them in your living room too, good for you. You save time and money!
All those tweaks are not the best things to do, it is a taste area, small gains compared to getting circuits and acoustics right... First things first. Best get good quality cables for pro equipment, hook up, leave them alone and proceed into changing real stuff. I do the same. There are smarter, comprehensive ways to change tone, and we learn too. On the other hand, us who have clearly heard what a single cap can do in our DAC or pre, or how a hook up wire changed the tone, and all the people around us could clearly hear it too, we would have been very dishonest to pretend that it is our fiction just because some demand hard facts. |
#1113 |
I can't hear cable differences. Tried small cable, big cable, cat 5 cable they all sound the same. Haven't tried coathanger but that's just ugly and there is no isolator.
Someone suggested huge car battery cable, now that's new and quite cheap too ... do you think it will make any difference? Less resistance? Distance is about 4m.
http://gainphile.blogspot.com |
#1114 | ||
People are saying "it's true because I heard it", and I am correcting that to "I believe it because my mind perceived it". Perhaps you are suggesting that there is no such thing as an error, it's all a matter of taste etc. There are two completely different things going on here. It's one thing for you to like a certain sound and me to prefer another. That's taste, that's personal preference. But it is a completely different thing to the question of whether an audible change in the sound waves in the room actually occurred. And an understanding of the role of the mind in creating a "different sound" even if there was no change in the sound waves in the room, but the listening context had changed. Quote:
There is plenty of room in our diy audio hobby for useful tweaking. For example modifying loudspeaker cabinets. Speaker placement, height and firing direction. Bass traps. Controlling reflections. Turntable resonances and motor issues. Upgrading undersized cables (not cable-swapping). Crossover tweaking. It is no disservice or spoiling tactic to raise awareness that cable-swapping and capacitor-swapping (without changing values) is an exercise that invariably draws the tweaker away from changing the sound waves in his room and into a world of self-delusion that is hypnotic in its persuasiveness. |
#1115 |
Hear hear! BTW, when I play something twice, it usually sounds different the second time. There are plausible explanations for an LP, but a CD? I rather doubt the sound-field in the room is any different, so it has to be the brain.
I used to be an audiophool like you but then I took an arrow to the knee. |
#1116 | |
Consistently on this board, and more strongly on others, I see people parrot objectivist mantras, from a subjectivist POV--"I didn't hear it no one can." I see people assault with "cable doesn't matter" when the discussion is about using 30 gauge speaker wire to push up the q of a low q driver--making a measurable difference. My problem is not with objectivist analysis--that is saying that there is no evidence, or established physical mode, that suggests a tweak should work. It is when those people treat it like a crusade and become hypocritical that I get irritated. Also when like in this thread they attempt to bait people with whom they know they will have a disagreement so that those people be "put right" for their own amusement -- creating an eyesore of a thread and absorbing people who could be making useful comments on other threads. I'm done with this. Sean |
#1117 | ||||
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#1118 | |
It would be easier to believe this test occurred if you provided the test parameters.
Conventional methods yield conventional results |
#1119 | |
Ecosse, The Maestro MA2 Ecosse, The Master Reference Ecosse, The Myth/Pro Ecosse, The Legend http://www.ecossecables.co.uk/Tables...ameset1_2.html |
#1120 | |||
Banned
Remember, they have trained themselves to "just listen" very carefully and have lots of experience doing so on their ultra "revealing" systems. They have self analyzed this training, self tested and based on the results, accredited themselves to be hearing superheroes, capable of leaping tall loudspeakers and small capacitors alike. Be not jealous, for jealousy lead to hate....and we know what hate leads to. Quote:
2) self constructed 100m track 3) self constructed or no timers 4) Friends or no witnesses etc, etc Cheers, AJ |
| Page generated in 0.25291 seconds (72.93% PHP - 27.07% MySQL) with 11 queries |
