Closed Thread
Old 21st January 2010, 05:58 PM   #11181
SY's Avatar
The 'mind control' repetition is starting to sound AJ-ish.
I'd agree there, too. I'm still mystified about how seriously you take a fourth-hand unsourced anecdote, lacking any detail or context, to support the notion of mind control.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 21st January 2010, 06:11 PM   #11182
Originally Posted by janneman View Post
I find it quite curious that even accomplished technical designers like Ben Duncan can make such a goof. I mean, it is very, very basic that when you have an attenuator made from a series reactive element (L or C) and a resistive element, that the phase shift changes with the value of the resistor (or the L or C). I really have a hard time to understand they fell into that trap.
jd
Now that you mention "phase shift changes with the value of the resistor", what would the effect of speaker drivers be on the other end of the cable?
Old 21st January 2010, 06:28 PM   #11183
event horizon's Avatar
Don't forget the crossover network Unless it was to quote Kef "conjugate load matched" i'd expect the reactance would send the impedance all over the place.
Must admit that they did kind of shoot themselves in the foot by changing the load resistor
"Never let your morals prevent you from doing what is right!" Salvor Hardin
Old 21st January 2010, 07:00 PM   #11184
fredex is offline fredex  New Zealand
Originally Posted by Jakob2 View Post
If you´d try to avoid any possible subconscious influence during the trial, then TG should listen alone. Wishes
Right, but you haven't addressed the last part of my post.
ie. would TG's knowledge that SY designed the test plus the knowledge of SY's opinions on cable sound be a factor, even though SY was not present during the trial?
Old 21st January 2010, 07:43 PM   #11185
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Its one of the sources of audible cable differences with 'boutique' cables. You can design a cable such that the effect is exaggerated, or possibly suppressed, so there is an audible difference, and naturally one cable will 'sound better'.
And yes, you can also 'steer' which is the one that sounds better.
jd
/Another new issue: Linear Audio Volume 3!
Old 21st January 2010, 08:00 PM   #11186
rdf is offline rdf  Canada
rdf's Avatar
Originally Posted by SY View Post
....to support the notion of mind control.
I can see 'mind control' being a necessity for otherwise impossible correct choices, but why for a null result?
Re: the citation, I couldn't confirm Meyer's anecdote. Most citations deal with cultural and ethnic differences. There was an interesting paper on the connection between self-esteem and performance as affected by immediate feedback in reasoning testing. Telling subjects in a social context they're delusional beforehand isn't covered.
Ears aren't microphones.
Old 21st January 2010, 08:04 PM   #11187
SY's Avatar
Nor is any other aspect of a DBT.
Old 21st January 2010, 08:20 PM   #11188
Pan is offline Pan  Sweden
Holy banana.. are you guys still doing this.. page 1119, unbelievable!! :-)
/Peter
Old 21st January 2010, 08:22 PM   #11189
I would say the cables with lower, more consistent delays should sound better. I would like to see more information on the cables used to compare with my testing.
jd
Possible yes, not so easy if you know what you want though.
Old 21st January 2010, 08:29 PM   #11190
rdf's Avatar
Assume a fictional subject capable of scoring correctly to a statistically significant degree in a cable DBT. Is it possible in principle for this subject to intentionally throw the results? Memorize a sequence of coin flips, pseudo-random make up answers on the fly, reverse 30% to drop the correct answers below significance; possible in principle? If so, why not subconsciously?
Closed Thread
Page generated in 0.20079 seconds (64.18% PHP - 35.82% MySQL) with 11 queries
