#10741 |
I did better than that, when I made my cable tests, always.
#10742 | |
Just consider Audio Precision. The analog section of their System One and System Two uses output transformers with hundreds of feet of plain ol' ETP copper wire. Judging by John's measurements, it would have been simply impossible to have created such a low distortion measurement system. se |
#10743 | |
#10744 | |
Although there are those who based on their "Faith" believe conductors are perfect, I have also measured deviation from perfect. I used an under 20mv twin tone as my excitation signal and measured distortion at -140dv or lower. (AX 11/09) I think with lower quality cables the results could be a bit worse. I also heated a piece of copper wire until oxide formed and noted no change before or after. So I do not think micro-diodes are a contributor to this distortion. Many of my early test were done on a soldered cable under test. No connectors were used. When I used RCA connectors (Neutrik) I found it mandatory to use De-oxit, otherwise the connector's distortions were dominant. I (OPINION) think there are several contributors to cable distortion at this low level. The question at hand is are these distortions large enough to be heard on a high quality sound system. Running a system at a low average voltage level such as 100mv with a high impedance load (100K) will lower your signal to noise & distortion ratios and make the cables contribution more significant. A 16 bit CD is limited to under 100db s/n. 100mv is -20db. Not very good cables for the sake of argument may be 130db clean. So for that case the distortion would be 10db below the CD's range. Can that be heard? Are there sources better than a CD? Note this is just a discussion of the effects of nonlinear resistance in audio interconnect cables causing distortion. There are other factors besides RLC, that may also affect the signals. So it seems clear that from the measured cable distortion in a system running at reasonable voltages and impedances from a source such as CDs it probably is not possible to detect any difference between reasonable quality cables. However even in such a system connector oxidation may cause problems. The question is left open if with better sources audio interconnect cable distortion is a factor. |
#10745 |
Higher order odd distortion is very easy to hear, even at very low levels. It doesn't matter whether it is the connectors (clean and tight) magnetic hysteresis, dielectric problems, solder or press fit connection, etc. Distortion is distortion. Still, it is just a distortion that I measured, it could CERTAINLY effect other measurements, for xover distortion in power amps for example, IF I just used any old connecting cable, many loved by the hear no difference types, here.
#10746 | |
Making measurements and then mindlessly running around telling people that there are micro diodes in their wires does ABSOLUTELY NOTHING to enlighten anyone. You do an awful lot of choppin' with that little axe of yours, but I rarely ever see any wood chips flyin'. se |
#10747 | |
one sign of advancing Alzheimers is the repitition of stories about events that transpired in the past, with no recollection of having mentioned such stories previously...
"...His brain is squirming like a toad..." Jim Morrison |
#10748 | |
I know nothing about those applications, how long does data remain in the analogue domain?
Blame the Manichaeists |
#10749 | |
Banned
Don't expect a (rational or other) explanation from JC as to why Mogami would be only "a start". |
#10750 |
| Page generated in 0.23822 seconds (66.68% PHP - 33.32% MySQL) with 11 queries |
