I don't believe cables make a difference, any input?
Closed Thread
Old 11th October 2009, 03:17 PM   #6281
On Hiatus
SY's Avatar
you normally donīt believe that there is any audible difference existing as long as no controlled test has confirmed the difference.
That is not correct. You left out all of the important qualifiers. I expect that sort of argument from the faith-based folks, but not from you.
Start with that incorrect assumption and your conclusions will be (as they are) incorrect. I've listed the qualifiers so many times over the years that you can easily find them in a forum search, if that's what you want to do.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 11th October 2009, 03:21 PM   #6282
Pano is offline Pano  United States
Pano's Avatar
Maybe this is why powered speakers sound so good? No cable at all (or so short as to not matter)
No cable is better than any cable, right?
Old 11th October 2009, 03:39 PM   #6283
Jakob2 is offline Jakob2  Germany
But, please bear with me, you were arguing with bias effects and Olive/Toole have shown that even the quite distinct differences of different loudspeaker models would not prevent against strong bias impact if tested sighted.
I assume that you mean with "important qualifiers" something like the known hearing thresholds.
So i still find it an interesting question, just because if there is no way to learn to deal with the several bias mechanism than a controlled blind test would be the only possibility.
Wishes
Old 11th October 2009, 03:54 PM   #6284
Key is offline Key  United States
Well that and someone who actually knows what to test for choosing the cable, the filters coming before the amp, and the amp being directly connected to drivers. Of course if this same theory is used by someone who has no idea how to test a system the theory will work against you and you will end up with a poorly calibrated system.
Old 11th October 2009, 04:15 PM   #6285
On Hiatus
SY's Avatar
You found one qualifier. There are several more. But in general, yes, if there's an extraordinary claim, a blind test of some sort is mandatory before making such a claim (if one is to be taken more seriously than my then-6-year-old sister's claim of having a hundred invisible horses).
The control of that test will need to be proportional to the outlandishness of the claim. If someone claims to hear a difference from a 3dB level shift, that's not outlandish. If someone uses a marginally stable amplifier designed by a magician and changing the cable seems to change the sound, sure, that not unreasonable and the bar isn't that high. That's been acknowledged about 200 times in this thread. So what? But asserting a difference because of factors outside of known physics or despite scale differences orders of magnitude below any reasonable threshold... well, I hope you're happy with your invisible horses.
Old 11th October 2009, 04:50 PM   #6286
rdf is offline rdf  Canada
rdf's Avatar
Originally Posted by quiet fish View Post
Sweet dreams I would not trust business people AN recommends Condo recommends but, it is hard to imagine they would recommend lamp cord
It would be hard to imagine they recommend the chip amps, but some do. In a DIY forum the cost of cabling is arguably a red herring. A pair of small gauge solid silver interconnects can be thrown together with Audionote connectors for the price of a pair of Levis. A Risch Belden design even less. There is essentially no social 'payload' or monetary bragging rights.
Ears aren't microphones.
Old 11th October 2009, 04:53 PM   #6287
@ SY,
if you could tell me a phrase that safeguards against all possible omissions of things we both know about, but still doesnīt take a whole page iīll be more than happy to use it.
Again, Olive and Toole have shown that even the distinct differences of loudspeakers (afair in the range of several dbīs, broadband peaks and dips etc.) will not prevent rating _and_ ranking of these loudspeakers to be strongly influenced by bias mechanisms.
Not an invinsible horse iīd think
So, if we are not able to learn to deal with all the possible bias mechanism, why should the passive network approach work?
Wishes
Old 11th October 2009, 04:57 PM   #6288
quiet fish is offline quiet fish  United States
I am not an expert here at all but, I believe that from an engineering point of view there should be an ideal connector between two components with certain characteristics.
Old 11th October 2009, 05:43 PM   #6289
syn08 is offline syn08  Canada
Originally Posted by Curly Woods View Post
It just amazes me the sheer amount of effort that has been expelled in the effort to try to change the minds of "hearing" side of this argument. To what length will this go in their attempts to persuade the "hearing" crowd to abandon their views?
Athough the reciprocal is true as well, and although the GEB motivation is not so difficult to identify as to be worth questioning about, to strictly answer your question: to me it's like supporting cancer research. Worth the effort, so far not much success, but still hoping to stop this disease for good .
Old 11th October 2009, 06:27 PM   #6290
On Hiatus
SY's Avatar
Since we can't cure 100% of cancers, why cure any?
One thing is for sure- people can hear frequency response changes on the order of magnitude of 1 dB. So if two cables cause frequency response differences because of, ahhhh, unconventional engineering in the chain, EQing the system to remove that difference is far and away the most likely way to eliminate any audible differences. For sure, it takes the claim of audibility from plausible to imaginary horses. At that point, it's up to the imaginative to do the demonstrating.
Closed Thread
I don't believe cables make a difference, any input?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
