I don't believe cables make a difference, any input?
Closed Thread
Old 24th January 2010, 12:56 PM   #11291
Panicos K is offline Panicos K  Europe
Panicos K's Avatar
Originally Posted by AJinFLA View Post
What is your approach in your room (given the small, cone 'n dome, vertically on the face of a resonating box approach of your speakers) to address post source acoustics? Wires?
cheers,
AJ
Perhaps it would be better if you take a more careful "look" at my speaker's "resonating box approach".I am working on my room treatment though.If results are good I'll post some details.My speaker's "resonating box approach" however,seems to have made things a lot more easier for my room......for some reason.Do you think it might be their resonances?
Old 24th January 2010, 01:06 PM   #11292
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by auplater View Post
There it is
The sheer anxiety for Mr Jeff Nelson to pop up in these circles is almost unbearable.
2008 Phoney => www.moremusic.nl/prijslijsten/boulder.pdf
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 24th January 2010, 01:13 PM   #11293
Panicos K's Avatar
We are all subject to it, not immune. However, some of us are aware and accept this fact, whereas others......
Btw, to address your earlier post (gone?)
AJ
Which post?
Old 24th January 2010, 01:25 PM   #11294
AJinFLA is offline AJinFLA  United States
Banned
I did
You are posting on a speaker building forum and don't know what this means?
You don't know what a (reflex) port is for?
So you are going to measure, or will this be the grope around and "listen" thing?
Wouldn't it be better to solve the issue at the source, rather than apply bandaids? You have Toole's book and what has been found via listening tests about absorption and (killing) spaciousness?
Wires play no role in your passive countermeasures?
Having measured (and listened to) many box speakers with rear resonating ports in real rooms....Doubtful .
cheers,
AJ
Old 24th January 2010, 01:35 PM   #11295
Panicos K's Avatar
cheers,
AJ
Have you measured their cabinet panel resonances?What is your opinion on their influence on final sound?Would you treat your room with a badly resonant speaker?At least the one I'm using has kept these cabinet resonances to a minimum.As for your question about reflex ports......no,I don't know
About room treatment,I have the "luxury" to borrow some and try them.I will surely choose(if I choose) the ones which will make final sound better to my ears because after I finish,I will be listening to my system,not measuring it.......Good guess I hope my illusions are good once more.
Old 24th January 2010, 01:50 PM   #11296
Banned
When you figure out the latter, you will then understand it was not referencing the former.
So you don't use wires for acoustic issues?
So you hope killing spaciousness and increasing non-linearity of the reverberant field will make final sound better to your ears.
As long as the treatments are expensive enough (not "cheap"), I'm guessing somehow, there will be an improvement. Good luck .
If not, the next leap in wires (price included) is just around the corner
Old 24th January 2010, 01:53 PM   #11297
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
That this topic got so explosive makes me speechless. I will not desturb you with my subjective findings any more. I will watch this tread and when i can contribute something that is resonable i may enter the discussion again. It got a one way road because the majority has already decided that cables of resonable contruction are good enough so what is the point to further elaborate ?
Old 24th January 2010, 01:57 PM   #11298
Panicos K's Avatar
So you don't use wires for acoustic issuees?
I always choose wires for acoustic issues,but not for altering FR if this is what you mean
About room treatments,that is why I said about the "luxury" to try them first.Don't worry about prices either.I may have some more "luxuries" to deal with them too.DIY'ing is one of them,so,don't get me wrong
Old 24th January 2010, 02:11 PM   #11299
Panicos K's Avatar
I do not have hopes for anything.My hearing tells me what I like to hear the same way as my taste tells me what I like to eat.I don't have any "references" that I follow.When I do things for pleasure,these things have to please me.Nothing more,nothing less.
Old 24th January 2010, 02:17 PM   #11300
Panicos K's Avatar
I know it wasn't,I was refering to the formerAren't those cabinet resonances part of the whole problem?
Closed Thread
I don't believe cables make a difference, any input?Hide this!Advertise here!
Copyright ©1999-2017 diyAudio
