Hi all,
I'm thinking of using a Peerless HDS Nomex 830875 as a woofer in a small vented 3-way project. Various modeling programs think that the "ideal" box is around 15L with a 50 Hz tuning. But I found that modeling a bigger box with a lower tuning could give a bit more bass (21-22L, 42-44 Hz tuning). It is wise to use a box bigger than the Vas and a tuning lower than the Fs? Are there rules about when it is possible or when absolutely not? Thanks in advance, Ralf The T/S parameters of the driver are: Fs = 48.1 Hz Qms = 2.67 Qes = 0.45 Qts = 0.39 Vas = 17.6 L Re = 6.4 Ohm Le = 1.3 mH BL = 8.4 |
#2 |
Did it Himself
Have a look at the curves for excursion and group delay or phase response. These will give you an idea of what compromises you are making. The software is showing common used alignments, there are thousands of alignments you can make up, each with their own merits and pitfalls.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 | |
![]() I prefer tighter bass, so I would choose smaller volume. It is your choice. Here are some useful online calculators for DIYers ![]() mh-audio.nl - Calculations Jernej |
#4 |
re:'Larger volume with lower tunning will produce lower bass, but not as clear. More boomy' - not necessarily, depends on where the tuning is and how well controlled it is.
What the OP is looking at is an EBS alignment, the price to pay for the lower extension is larger box and a lower output level, as well as what Richie00boy said. Group delay can be bypassed if the tuning is low enough, excursion may be more of a problem if you like lots of low bass loud (depends on the drivers capabilities)...
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#5 |
You can within certain limits "compliance scale" one alignment to another.
In your case for instance you want a 40Hz. out off if you divide the cut off of your current alignment by this then multiply your current box volume by.. (50/40)^2.5, you get around 26litres If you divide the current tuning frequency by (50/40)^.5 you get the tuning frequency, around 45 Hz. Theses alignments are of the Chebashev sort and have ripple. Overall a ten inch driver is better for 40Hz. rcw. |
#6 | |
I agree with everyone else, the down side will be an increase in excersion limits and a little less detail in bass and lower midrange. The driver has to work harder and you will hear the difference. It's all about finding the balance that suits you. Terry
What we don't understand is called magic. |
| Unibit Rules! | KT | Parts | 12 | 31st August 2010 07:51 AM |
| Vent volume | REALFLEO | Multi-Way | 3 | 30th January 2007 02:49 AM |
| Effect of enclosure volume deviation on vent tuning? | rxwilson | Multi-Way | 2 | 7th January 2007 10:18 AM |
| X 250 Rules...Less is more | macka | Pass Labs | 26 | 9th July 2005 02:26 AM |
| Rules for capacitors... | Htguy | Analogue Source | 4 | 28th May 2005 07:06 PM |
| Page generated in 0.09110 seconds (80.26% PHP - 19.74% MySQL) with 10 queries |
