im going to attempt to build a 4x12 cab and i am pretty new to all this electronic stuff so i need help. First question i want to put in 2 eminence governers(75 watt each) and 2 EMinence tonkers(150 watt each) will the difference in watts affect function? im attempting to make an 8 ohm cab so all these speakers are 8 ohms how is the wiring done on this to make it 8 ohms. And if there is any other tips you can give me on building this that would be much aprreciated
P.S. if answering my questions think as if your talking to a person with a brain the size of peanut when it comes to this stuff thanks |
#2 | ||
Had to answer because I can shamelessly plug one of my recent projects
![]() Quote:
I'm attaching pics of my 4X12. It is built to roughly Marshall 1960A dimensions but nothing like it in construction: it is a simple glued box.
Aerodynamics are for people who can't build engines. Enzo Ferrari |
#3 | |
cool thanks im thinking of making it a straight cab with a removable back do you think this work well? and if you have a pic of the wiring of your cab could you post that please thanks |
#4 | |
Sure, that will work. Countles websites on wiring 4x12's out there. ![]() Wiring a 4 X 12 Speaker cabinet
#5 |
Thanks man appreciate it will post pics when im done
#6 | |
thanks also one other question i read that if a cab is rated at 500 watts or above it needs speakon connectors my cab will clock in at aroun 450 watts will this constitute speakons and i see speakons used mostly with bass and p.a. so would it be compatible with guitar? |
#7 |
Speakerholic
Thought I'd move this over to the speaker section
#8 |
you might think about mixing up the distribution of the two varieties for a better mix of sound too. i.e. a tonker and gov on top and the reverse for the bottom. I say this because unless the box is elevated you will hear more of the high end from just the top 2 speakers. Also, and I know its more of a hassle to build but, if you only have one cab its pretty nice to have a slanted.
"You have fallen into my plan trap!" |
#9 |
In response to your power/speakon jack question, speakons only really matter if you're going to consume that kind of power(something tells me you're not going to run a 400w amp into this thing and run it to clipping). Also, if you're going to play live spare speakon cords are harder to come by then spare 1/4 in if you happen to kill/lose one.
#10 |
Could always fit it with a 1/4" jack, and a speakon, then you'll be prepared for anything!
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo My setup: http://www.diyaudio.com/forums/multi...tang-band.html
| Increasing bass response in a 4x12 cab | burning | Instruments and Amps | 2 | 9th January 2008 01:17 AM |
| Marshall 4x12 cab | tareqx2 | Instruments and Amps | 22 | 18th September 2007 10:47 AM |
| 4x12 Speaker cab wiring question | mytool4u | Instruments and Amps | 28 | 8th August 2007 10:15 PM |
| wiring diagram for 4x12 guitar cab | carlosy | Multi-Way | 1 | 2nd June 2006 02:31 AM |
| diy 4x12 cabinet | thejukeboxhero | Multi-Way | 2 | 12th December 2004 08:33 PM |
| Page generated in 0.12601 seconds (77.10% PHP - 22.90% MySQL) with 11 queries |
