Old 29th November 2009, 09:31 PM   #1
jsa_ind is offline jsa_ind  United States
Smile Acoustic Center
In a Line array of four 10 inch woofers, how does one find the "Acoustic Center" of the Line array?
Is there any software that can either model the "Acoustic Center" or physically calculate the same?
Thanks for your inputs in advance!
jsa_ind
Old 30th November 2009, 03:32 AM   #2
gedlee is offline gedlee  United States
The whole concept of "acoustic center" was abandoned by the Standards group of AES several years ago because it could not be defined unambiguously. Basically there are a great many situation where the so-called "Acoustic center" is moving all over the place. There is no single place that can be called the "center".
Better is to think of excess group delay from some given point. In this case it doesn't matter where that point is so long as its fixed in space.
Old 30th November 2009, 04:02 AM   #3
Thank you Sir for the quick response!
Could you please advise how does one calculate the "Excess group delay" from a given point when it comes to a line array of four woofers?
Thank you!
jsa_ind
Old 30th November 2009, 04:18 AM   #4
I believe that most measurement software will do that.
Group delay is the rate of change of phase with frequency. There is going to be a "mean delay" which is as close to the "acoustic center" concept as you will get, and there will be variation from this mean which can be called the "excess group delay". This will tell you how stable the acoustic center is with frequency. In general one wants the excess group delay to be small, in which case there actually is a clearly defined acoustic center, but in practice there will always be some excess group delay and hence an ambiguous location for the acoustic center. Line sources will defintely have a large excess group delay by their very nature.
Old 30th November 2009, 09:16 PM   #5
Thank you Dr. Geddes for all your inputs!
jsa_ind
Acoustic center of horns mrkramer Multi-Way 5 29th January 2009 08:32 AM
Determining Acoustic Center akunec Multi-Way 4 24th May 2007 08:31 AM
A (re)introduction to all, and a specific acoustic center question gtphill Multi-Way 2 19th March 2007 03:31 AM
Dynaudio D76 Acoustic Center? DaveThreshold Multi-Way 2 20th May 2006 11:35 PM
Acoustic Center? angsuman Multi-Way 5 18th April 2006 10:25 AM
Page generated in 0.06678 seconds (79.77% PHP - 20.23% MySQL) with 10 queries
