Old 28th November 2009, 03:39 AM   #1
dcathro is offline dcathro  Australia
Default Looking for Hi End OB Mid
I am looking for a hi end midrange to put in an OB.
I am trying the Seas Exotic W8 8" along with the T35 tweeter, but it might not work out.
I need something that it efficient 93db +, and will operate between 250 Hz and 1.5 KHz with 1st order filters.
I saw these:
Accuton C173N-T6-90, 6.5" Midrange, 93.2dB (was C90-T6) from Madisound
but don't know whether they would like an OB, and have heard that they may no longer be available.
Bass will be provided by a pair of 15" JBLs (K145s with field coil motors) in a 150L vented box.
David
Old 28th November 2009, 03:45 AM   #2
d to the g's Avatar
This is where I'd suggest you take a look at wild burro audio. Just dewhizzer the betsy and you'd have everything you're asking for... and more.
Old 28th November 2009, 05:34 AM   #3
jamikl is offline jamikl  Australia
dcathro have a look at the PHL speakers at Audiomarketplace - Home.
jamikl
Old 28th November 2009, 06:09 AM   #4
ttan98 is offline ttan98  Australia
jamikl
I remember they sell PHL drivers, but I cannot find PHL drivers anymore at their website. I have PHL drivers myself, model PHL 2460 a cheaper version of the highly regarded PHL1120, very expensive, US$175 each, selling in the States. They are very good.
Old 28th November 2009, 08:59 AM   #5
You are correct ttan. They were still listing PHL a few weeks ago but the
site had not been updated in a long time. Now it has been updated and they are no longer listed. They also stocked some Etons which are no longer listed.
Getting harder and harder to diy here.
jamikl
Old 28th November 2009, 04:30 PM   #6
Helmuth is offline Helmuth  Netherlands
Helmuth's Avatar
Good question, but when is a speaker high end?
Old 28th November 2009, 05:11 PM   #7
TerryO is offline TerryO  United States
TerryO's Avatar
Helmuth,
The answer is quite simple:
A speaker is high end when I say it is!
Ok, I'm kidding but I thought that this question was in need of an authoritative answer. It really has no universally accepted answer from what I've gathered over the years.
Best Regards,
TerryO
"If you have to ask why, then you're probably on the right track."
quote from Terry Olson's DIYaudio Forum application
Old 28th November 2009, 05:56 PM   #8
tinitus is offline tinitus  Europe
Sweet looking mid driver
Scan-Speak 10F/4424G Discovery, 4" Midrange from Madisound
I havent seen this 4" before, only the 5-6"
But I say its high end
Old 28th November 2009, 07:18 PM   #9
Helmuth's Avatar
Wrong TS-parameters for OB.
Old 28th November 2009, 07:44 PM   #10
ScottG is offline ScottG  United States
If you crossover low enough (between the tweeter and the W8), AND have a baffle wide enough to support the freq. you want and the high-pass character you want from the W8, then I don't think it's likely you can do much better..
The integration will however be key to your success.
You also might want to consider a dipole response for the tweeter as well, which would require another tweeter on the rear with a similar eff. and bandwidth (..though not requiring another T35). Alternativly IF the baffle is large enough - look to a BG Neo8 PDR as a dipole radiator (..which will also cost a hell of a lot less than a T35 plus rear driver).
perspective is everything
Page generated in 0.12212 seconds (74.81% PHP - 25.19% MySQL) with 10 queries
