Troels' PMS (multilayer assembly) build thread
Old 2nd December 2009, 12:25 PM   #21
WaveFlex is offline WaveFlex  France
WaveFlex's Avatar
Installation of the cross-over on the bottom-plate
Cross-overs are bolted to the bottom plate using "silent-blocks" which are actually nothing else that short pieces of isolation from a 50mm˛ power cable.
Does not look very engineered, but should uncouple the cross-over mechanically from the cabinet and from the "feel" it gives will do it's job.
Looks huge actually
http://www.waveflex.fr/
Old 2nd December 2009, 08:27 PM   #22
WaveFlex's Avatar
Here we go with the dry assembly...
Installing the 10mm threaded rods (3/8" should do as well) on the bottom plate (rods are 1 m overall length) and assembling back-side-parts
Assembling the front-side parts :
Adding one bracing
Going on with some rear and front-side elements
Top view showing the groove in the back-side parts
More parts
Old 2nd December 2009, 09:29 PM   #23
WaveFlex's Avatar
Just keep it going...
Bracing for the woofer area
Fitting 1/4 parts on the front-side of the cabinet for the front-plate (using 1/2 or 1/4 drastically reduces raw material consumption for only slightly longer machine time)
Tiling them up, tiling them up... a couple of minutes later (no kiddin')
Wofoer area assembled, lower mid-volume enclosure in place
Some more parts for the the mid-volume, a total of 7 are necessary for the 4 liters something needed
Finally the closed volume
The cut-out on the top-layer is for fitting the mid, we'll see later that it will cause some trouble...
Old 2nd December 2009, 10:18 PM   #24
WaveFlex's Avatar
Skipped the starting point in the previous post.. here it is.. bolting the rods to the bottom plate
and this one
Rear-side view showing the curve of the cabinet
Old 3rd December 2009, 12:43 AM   #25
SamL is offline SamL  New Zealand
What a beauty.
Is the small baffle that driver mount on to, is it replaceable?
Old 3rd December 2009, 12:42 PM   #26
WaveFlex's Avatar
Originally Posted by SamL View Post
What a beauty.
Yes, basically it is, but the real question is what kind of drivers to fit instead!
Old 3rd December 2009, 01:25 PM   #27
WaveFlex's Avatar
Finished dry assembly
Front view
Rear view
Playing around with the parts, using some of them upside-down, gives this.
Yet another reason not to paint them..
Old 3rd December 2009, 01:45 PM   #28
WaveFlex's Avatar
After correcting the positition of the front plates (they were too low actually) and fitting the ground plate this is what it should look like at the end.
Front view
Rear view
With the front-plates
Old 3rd December 2009, 01:58 PM   #29
Dr_EM is offline Dr_EM  United Kingdom
Dr_EM's Avatar
A fascinating construction! Should be really solid when completed
Old 3rd December 2009, 02:59 PM   #30
WaveFlex's Avatar
Some inside views...
Troels' PMS (multilayer assembly) build threadHide this!Advertise here!
SE - Build Thread soundengine355 Solid State 6 27th June 2009 12:19 AM
My SE KT-88 Build thread athos56 Tubes / Valves 13 21st December 2008 06:16 AM
The ESL Build Thread BillH Planars & Exotics 172 8th November 2006 09:01 PM
Multilayer ground maczrool Digital Source 53 11th July 2005 11:41 PM
Print your own multilayer PCB Petter Everything Else 0 1st November 2004 01:25 PM
