S12 OB - Returning to true OB
Old 25th November 2009, 06:15 PM   #11
skorpion is offline skorpion  Sweden
I am afraid you don't understand anything of this Telstar.
/Erling
Old 25th November 2009, 06:29 PM   #12
Telstar is offline Telstar  Italy
/Erling
I beg your pardon?
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 25th November 2009, 06:36 PM   #13
Why should you ?
/Erling
Old 25th November 2009, 06:38 PM   #14
I am sorry, thread would be useless now I suppose.
/Erling
Old 25th November 2009, 06:43 PM   #15
cuibono is offline cuibono  United States
cuibono's Avatar
Originally Posted by Rudolf View Post
To the right on top of the 6.5'' midrange driver in the picture are two Dayton ND20FA-6. They are mounted back to back in a short piece of plumbing tube. Diameter of this 'point source' is 4,5 cm, depth is 3,3 cm.
I have not listened to them yet, still using the double Monacor DT 25N on the left. But the Daytons are almost half that size and should be even better imaging.
I have a handful of ND20FB drivers I've meant to do the same thing with - the only issue I see is power handling. Tell us if they burn! Otherwise, they look to be very good for the application.
Regarding baffles and No baffles, Gainphile seems to take a step 'backward' with this new baffle and Rudolf, as always, going front to improve our stereo sensation.
Couldn't the two of you settle this discussion, also provoced by Stig-Erik's thread, of baffles or no baffles, small or more substantial, by measuring various baffle sizes and no baffles at different angles. I suggest 1 m distance and 15, 30 and 45 degree angles, in room measurement. This would be very clarifying for our future developments.
/Erling
There are lots of measurements around the forum - the results are fairly simple - the smaller the baffle, the higher the dipole peak. Dipole speakers maintain a uniform off axis response up to about the dipole peak, then it degrades. (Additionally, the magnet/frame structure interferes with things in the 1-2kHz range.) The compromise with smaller baffles is more low end loss of sensitivity. How anyone wants to apply this is up to them and subjective.
Old 25th November 2009, 06:48 PM   #16
cuibono's Avatar
Originally Posted by gainphile View Post
This one is to build a true open baffle with its simplicity (no h/w/u -frame etc.) I think there is something about them which other variation simply can't match.
Obviously the low-end output is severely limited .
Looks nice! I enjoy your explorations. Something to consider wrt the 'sound' of your woofers is that you are probably pumping more power into them - so if you wanted more things to 'worry' about, you might be getting more heating in the voice coil, and distortion from your amp. Just food for thought. I worry about this stuff, but only a little.
Old 25th November 2009, 06:49 PM   #17
Cuibono, thanks !
I was not really aware of your observations. I can see that baffle size is very much dependent of subjective thoughts and some objective overwiews regarding baffle size. Possibly the 2.2 rule of thumb would be the best then ?
/Erling
Old 25th November 2009, 07:28 PM   #18
About the Daytons, if you ask me they are a bit low in sensitivity. I have used the Monacor DT28N but they may also be less omnidirectional than you would like.
/Erling
Old 25th November 2009, 07:35 PM   #19
I think I may have abandoned my first question too fast ? May be baffle and no baffle is a more fundamental question ?
/Erling
Old 25th November 2009, 09:21 PM   #20
HiFiNutNut is offline HiFiNutNut  Australia
My only explanation is, with h/u frames the polar response is not as uniform as simple OB.
Does it matter much at and below 125Hz? I don't think so.
Would you post some measurements?
By the way, nice looking speakers.
S12 OB - Returning to true OBHide this!Advertise here!
Our webmaster Dan (Audiofreak) is retiring, returning later as a moderator Jason Site Announcements 53 26th July 2011 04:01 PM
True-RMS? star882 Parts 8 1st June 2007 02:35 AM
Returning member TubeHound Introductions 4 20th May 2007 08:04 PM
Is it true? rick57 Digital Source 4 31st October 2006 08:50 AM
Returning fanatic LawWolf Introductions 4 14th July 2006 01:43 PM
