Old 24th November 2009, 08:53 PM   #1
Default Double Chamber Reflex (Silver Flute W17RC + Seas 17TDFC)
I have earlier tested a 6-1/2" Silver Flute in a 15L BR. As expected, needs to be supported with subwoofer. On its own, bass is a bit "short" due to early roll off.
This is an attempt to design a 2-way that has bass extension down to 40-45Hz using the concept of DCR.
Components
Woofer = Silver Flute W17RC38-S-8
Tweeter = Seas 27TDFC
Gross Box Vol = 40L (Internally divided to 2 chambers)
Smaller Chamber = 13L
DCR tuned with 3 PVC Tubes. One in each chamber and the 3rd one between the 2 chambers.
PVC Tube = 2" Dia x 3.1" Length
Chambers lined with R11 Fiberglass wool.
AmpsLab.com
Old 25th November 2009, 12:02 AM   #2
Default Deciding on the Box
T/S measurements done with LMS (20g Delta Mass). As can be seen, they are quite different from the manufacturer's specs.
In the box modeling, the black plot is how the response looks like when tuned to 37Hz in a BR of 40L. In a DCR, there will be a bass boost at F1 (37Hz) and F3 (80Hz). F3 is the port of the smaller chamber. F1 is in the bigger chamber where the woofer and tweeter are located.
There is another port, F2 (42Hz), that connects the 2 chamber within.
More information on Double Chamber Reflex can be found at:
Claudio Negro's home page
AmpsLab.com
Old 25th November 2009, 12:14 AM   #3
mdynac is offline mdynac  United States
hi,
first off, kewl project....
i too have a set of the silver flute 6.5" 8 ohm
i have them in a set of Parts Express BR-1S (99 bucks, could not pass it up!!!) i took the shielded woofer out and put in the SF with a new crossover 3500 hz 1st order. the cabinet is like 15 liters, i plugged the port with a sock....
sounds wonderful, at least the woofer does, and yes it needs a sub.
how did you decide on the tweeter?? and what are you planning for a crossover? i am tweeter hunting right now and your input would be appreciated.
i think the silver flutes have potential.
Fulton Tempo
Fulton Midget Monitor
Old 25th November 2009, 12:19 PM   #4
Hi mdynac.
I've always wanted a 6-1/2" 2-way to go down low without having to resort to a 2.5 or a sub. I believe this DCR can do just that.
The Silver Flute W17RC is a nice woofer. Very reasonably priced and generally good performance. Flat response until some cone breakup which is not too drastic. I don't think there are any other 6-1/2 that has similar response at this kind of price.
When I tested out this woofer earlier, I had it mated with a Vifa D25AG35 in a 15L BR, just to have an idea of its character. I crossed them initially at 2K5. Unfortunately, I picked out some distortion in the D25AG, even with 3rd order HP. I am sure it has something to do with the rear chamber. Doesn't seem to affect others but drive me nuts. Moved the crossover to 3K5. Distortion disappear but lost the mids.
To cross at 2K5, I will have to correct the D25AG issues passively or even mod the tweeter. I don't want to go to all the trouble and complicate things. I rather keep this design as simple as possible so that its easy for diy.
The Seas 27TDFC has the properties that I am looking for. Flat response, low Fs and being a newer design, I hope none of the resonance issues with the rear chamber.
The SF W17 will be crossed at 2K5 to the 17TDFC. The LP for the W17 will be 12dB. This will keep the cone breakup farther away from the cross point.
The 17TDFC HP will be 18dB. I like to keep the lows away from the tweeter. They are always more comfortable.
AmpsLab.com
Old 25th November 2009, 01:00 PM   #5
The DCR loaded with SF W17RC and Seas 17TDFC.
One port in upper chamber, one in lower chamber and last one connects the two chambers internally.
At the rear, top left, is an Altec Lansing CD912-8A Duplex. Not final yet but promising.
AmpsLab.com
Old 25th November 2009, 04:55 PM   #6
Plot1 = DCR Impedance Sweep
As predicted, F2=44Hz and F3=85Hz.
Plot2
1) Purple = Raw Z of SF W17
2) Yellow = ZOBEL (11 ohms + 12uF) applied. Region of interest is from 1K - 10K.
Plot3
Raw Z of Seas 27TDFC. Fs is 550Hz, exactly as stated in the manufacturer's specs.
All plots swept with 2Vrms
AmpsLab.com
Old 25th November 2009, 08:56 PM   #7
Which application models the double chamber reflex?
"A friend will help you move. A really good friend will help you move a body."
-Anonymous
Old 25th November 2009, 09:07 PM   #8
Any program that models reflex enclosures, plus the formulas from Claudio Negro's DCR page:
DCR
Old 25th November 2009, 10:15 PM   #9
Mosquito's Avatar
The third system (left to right) in C.Negro's page, is the one that work best with highish Qt, low Vas woofers. And as long as I know, can be modelled with LSPCad. But parameter insertion done manually, the automatic alignement routine will lead you off road. I suspect Leap can do the job as well...
Old 26th November 2009, 04:31 AM   #10
I don't think there's any specifically for DCR. You can use any for BR programs to tune the box for your desired Fb. From the formula, you can calculate the F2 and F3.
Using LMS, I will measure the actual acoustic response of a DCR. It will give us an insight as to how different it is from a normal BR.
AmpsLab.com
DCR Double Chamber Reflex Subwoofer gpsmithii Subwoofers 0 3rd September 2008 02:15 PM
Double chamber reflex rebellion Hezz Multi-Way 13 25th February 2007 05:58 AM
Double Chamber Reflex Vent Question Guss Multi-Way 16 26th June 2004 07:44 PM
quick question about double chamber reflex nobody special Multi-Way 3 11th June 2003 04:54 PM
Page generated in 0.13174 seconds (73.75% PHP - 26.25% MySQL) with 11 queries
