Need woofer advice for Alpair 50 wide range build
Old 24th November 2009, 04:03 PM   #1
tybox2000 is offline tybox2000  United States
Talking Need woofer advice for Alpair 50 wide range build
I'm new here and need some advice on driver selection. First I'll tell you I have only built a few kits from Occam Audio before. I built 3 MTM 4 kits as my L-R and Center for home theatre and am well pleased with the sound.
I recently picked up a pair of Mark Audio Alpair 50 (grey) drivers on closeout special. They have a wide range from 300-20,000 so I have my upper end covered and want to get some advice on selecting a woofer for a nice simple 2 way large bookshelf build.
I noticed that Occam has a kit MT27 that uses this tweeter/mid and a SDX7 woofer from CSS. Problem is they are around $100 each woofer.
Can anyone recommend a 6"-8" woofer around the $50 dollar mark that would blend well with the Alpair 50, and also where a person can get a simple 2 way crossover kit for crossing over at 300hz?
Thanks in advance
Old 24th November 2009, 04:34 PM   #2
planet10 is online now planet10  Canada
frugal-phile(tm)
planet10's Avatar
Gregg-the-Geek has used Silver Flute (the 5") with good result.
dave
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 24th November 2009, 06:08 PM   #3
Ling Gowa is offline Ling Gowa  Canada
Thanks in advance
Where are you located?
Old 24th November 2009, 06:25 PM   #4
I'm located in St Louis, Mo
Need woofer advice for Alpair 50 wide range buildHide this!Advertise here!
Initial Impressions: Alpair 12 full-range driver by Mark Fenlon drspence Full Range 81 19th June 2010 07:28 AM
Alpair 10 wide bass driver and Alpair 10 Fullrange _henry_ Full Range 71 15th March 2009 11:37 AM
Wide dispersion speakers using full (wide) range drivers ozziozzi Full Range 1 28th December 2008 06:13 AM
Good wide range mid. neutron7 Multi-Way 3 28th January 2008 03:33 AM
wide'ish range driver? dunderchief Multi-Way 1 17th July 2004 11:27 PM
Copyright ©1999-2017 diyAudio
