#231 | |
In other words, you claim audible artifacts but can't actually point to any music that makes them show up. Which means more likely than not you can't actually hear the things you claim to be able to hear. Typical audiophile. Next are you going to go off on how magic tubes and expensive wires are?
And "versions?" It's a goddamn piece of computer code. |
#232 |
I've found this to be the case in many of my discussions with you. It makes having a discussion pointless because the statement above makes your comments uncredible.
#233 |
Well I am not trying to invalidate your opinions. And I don't see where I am saying that your opinions are wrong in any of these threads. Truth be told with a lot of these things we are talking about I am actually thinking that more than one person is "right" in there opinion. Maybe if you give me a specific. I am really not trying to come off as some know it all I just have personal preferences and opinions on certain things.
And Pallas you might want to read up a little on how DPLII was invented. Fosgate made the prototype all tube based. It was then up to the engineers at Dolby to port his analog invention to DSP. Further more if you are intimately familiar with linear phase shift networks or basically any means to achieve a linear 90 degree phase shift then you will see that no two are alike and not one of them is perfect. Therefore each computer code will most likely have deviations in it depending on how they implement it. You lose. |
#234 |
It wasn't in this thread, but another. You were very quick to write-off some data that I had referenced (my own I might add) by simply disagreeing because that was not your opinon. Holding an opinion based on no data (which you stated you will do) which lies in direct contradiction to existing data is not very intelligent. You cann't support your position by simply claiming that "I don't believe everything that I read". That may be true in many cases, but not when what you should have read is solidly substantiated with science.
Its a big problem in these forums that people hold opions with no supporting evidence that clearly contradict the available evidence - thats called religion and it has no place in audio. |
#235 |
Are you talking about asymmetrical phase distortions?! I gave you a couple of chances to double check that. I also double triple, quadruple tested myself in the mean time. You really think I am wrong? I think I am 100% right about the subject and I REALLY didn't want to call you on it. I stopped myself and sort of gave you examples before I decided to give my own lighthearted examples where I double and triple checked that I wasn't making some sort of mistake. I would have appreciated if you took a listen and maybe just told me where my mistake was if you saw one. But I was left in the dark. I still think I am right and I have posted proof of it which you can easily repeat yourself. I think I was a little offended by the "wasting your time" comment and your assumption that I haven't read any papers on the audibility of phase changes. It was simply that I did not know how FAR you could push the concept.
#236 | |
So I don't even know what it is you are claiming, but I know that your methodology is so weak that I'm not about to reject my results and accept yours. By "waste your time" I menat just what I said above. No one but you is going to accept the test as you have performed it. Before I would ever "listen" to anything I'd have to see the math behind it and then check that the examples implimented precisely what was being claimed - AND NOTHING MORE! Otherwise I could be listening to something completely unrelated to what was claimed and coming to a completely false set of conclusions. People simply do not seem to understand that poor testing methods are not "better than nothing" - very often they are "worse than doing nothing" because they give you false data. |
#237 |
Amen.
#238 |
All I got from you was basically that you do real tests and your opinions are therefore objective. You say I stick my head in the sand in light of objective proof (can cut the hypocrisy with a knife) yet you didn't even bother to take a listen to my examples. I have read paper after paper on the subject so I think your assumptions about how I spend my time were uncalled for frankly.
Would you call a polarity inversion an "all pass filter"? Would you listen to your speakers with mix match polarity? Seems kind of obvious to me I am objectively correct or either we are talking about two completely different things. Further more would you actually argue that by altering the phase relationships of the speakers you are not altering the arrival times at the ears of the listener? Seems like you are to me. And do you really think I need a controlled test with subjects to prove to myself such an elementary truth in psychoacoustics. God if I had to work like that I would never get anything done. Last edited by Key; 23rd December 2009 at 07:59 PM. |
#239 |
http://www.physics.sc.edu/kunchur/pa...---Kunchur.pdf
Some reading since you seem to respect that more than my "real world" examples. |
#240 |
Now we know that listening to a 7 kHz square waveform makes very small time errors detectable. That study hardly allows any conclusions to be draw for music reproduction. Most psychoacoustic studies share the same fate.
Best, Markus |
| requesting information | Cisco59nord | Parts | 3 | 14th May 2008 12:32 PM |
| 6P3S SE amp requesting | jkraxi | Tubes / Valves | 1 | 20th December 2007 12:43 AM |
| Requesting CLIO Data | teodorom | Multi-Way | 0 | 19th June 2004 08:11 AM |
| Requesting the voices of experience on box design | bostarob | Multi-Way | 11 | 16th April 2003 05:18 AM |
| Page generated in 0.12247 seconds (83.31% PHP - 16.69% MySQL) with 11 queries |
