Ok...Consider this....a pair of active bass bin/stands with response from 30-100hz topped with a passive MT using Seas Ca18rly/27tdfc sealed with and F3 of 70hz. HT/Music use so some dynamics involved.
Couple of options.......Use AVR filter functions at 80-100hz and send mono signal to bass bins/subs, Send Bass Bins full range signal from AVR L/R pre-outs and use plate amp 2nd order LP and speaker level inputs to MT's no filter OR use speaker level inputs to bass bin plate amp and speaker level outputs on plate amp to drive mains.....the latter two options resulting in true stereo seperation to 30hz. |
#2 |
Not sure there's any stereo information recorded below70Hz but we're purists so stereo it is
![]() Assuming these speakers have perfectly flat response to their limits then roll off as 2nd order bandpass (theoretical - right ) you'll need some XO function to integrate them properly.Without test gear you're guessing so, line level AVR pre-outs to the bass plate amps, tweak the plate amps XO point & level until it makes the hairs on the back of your neck tingle.
#3 |
Did it Himself
This one and set the plate amp to get a good blend with your mid/tops. All the other ways will screw up the blend.
Send Bass Bins full range signal from AVR L/R pre-outs and use plate amp 2nd order LP and speaker level inputs to MT's no filter.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
| DIY Low Pass and Mid/High Pass (Bass Blocking) Filters | runslikealpaca | Everything Else | 1 | 19th June 2009 10:59 PM |
| Question about power amp built in high pass filter | crippledchicken | Solid State | 0 | 22nd October 2008 06:09 PM |
| Need High level, high pass crossover for 250watts | Anthrax | Multi-Way | 0 | 21st January 2007 03:34 AM |
| high gain 2nd order high pass active filter topology | sreten | Solid State | 21 | 23rd March 2006 01:26 AM |
| variable Low-Cut, High-Pass & High-Cuts | TobWen | Solid State | 3 | 14th September 2004 09:40 PM |
| Page generated in 0.08476 seconds (75.36% PHP - 24.64% MySQL) with 10 queries |
