Does a digital crossover with RCA (unbalanced) input/outputs exist?
Old 23rd November 2009, 10:02 PM   #21
doug20 is offline doug20  United States
Originally Posted by panomaniac View Post
Just PM me, I'll help. And I think you have my email. "Mardis"
EDIT: Glowbug posted while I was typing. You can buy the Jensen bare transformers and DIY for a lot less.
Or buy some Edcor just for a listen - cheap! Then go with better iron if you like it.
Thanks,
Yes, I have email Mardis. He has been busy all summer and Im not in the position to do his mod right now.
back on topic, Thanks Gooki, I will check out that Clarion choice.
Old 24th November 2009, 10:29 PM   #22
markus76 is offline markus76  Germany
Banned
Hi Doug
You probably know this board already:
http://www.selectronic.fr/dcx2496_US.asp
Scroll down to "I/O BOARD kit".
The only digital crossover with RCA inputs I know is Sitronik-Industrie
Sorry, German only.
Best, Markus
Old 28th November 2009, 10:45 PM   #23
FE3T is offline FE3T  Norway
Ground Sound
look here for RCA option: http://www.groundsound.com/FAQ/RCA_DCN.jpg
RCA to XLR cable:
If you got a single-ended RCA / chinch output of your pre-amplifier you still have the possibility to exploit the performance of the balanced input of our digital crossovers. You could make an adaptor cable with RCA connector in one end of a microphone cable (2 conductors + shield) and a XLR connector at the other, especially if the cable is longer than 5m. I call this kind of cable “pseudo balanced”, because you still get the benefits of the balanced input without a real balanced output. To enhance the performance a bit more you could add a physical small resistor (value 100R) and fit it in the RCA connector. The resistor does the same as the output impedance of the pre-amplifier. The noise introduced on the cable will be balanced out at the input stage of the balanced input. Connect like this: RCA inner connector - red conductor – XLR pin 2 (hot), RCA shield – resistor (100R) or short – white conductor – XLR pin 3 (cold), RCA shield – wire shield – XLR pin 1 (neutral). RCA to XLR cable
Old 29th November 2009, 03:30 PM   #24
Originally Posted by markus76 View Post
Hi Doug
Selectronic : Vente par correspondance de composants électroniques
Sorry, German only.
Best, Markus
Thanks Markus, Im aware of that one. My soldering skills are about a 1 out of 10
but I guess its time to practice and improve!
Old 29th November 2009, 03:32 PM   #25
Originally Posted by FE3T View Post
Ground Sound
RCA to XLR cable:
Thank you!! That kit looks interesting.
Going through the PDF its says "Box, power switch, connectors,
wires are not included in the kit."
Where can I find a box, power switch like the ones shown in the PDF?
Nevermind, I think I found the box and kit on your site.
Im shocked that no one in the US is doing this stuff, Hpex, these links are all over seas so the shipping and the exchange rate is killing me.
Old 29th November 2009, 03:35 PM   #26
Banned
Doug
You can buy the Selectronic board fully assembled for $500.
What about a software solution like (((acourate)))® - Room Correction, Speaker Optimization and Sound Improvement
Best, Markus
Old 29th November 2009, 09:11 PM   #27
Absolutely, i have been drooling on these for a while myself.
(Setting up a large surround system consisting of a Technics SH-AC500D prosessor and sofar, 3 SE-A900s poweramps (trying too buy a 4th one now)
Aims for 5 amps powering 5 identical DIY active 2 way speakers and Hypex power for a number of 15" subs
I have no problem imaging that, even if the exchange rate NOK too USD are very favourable and US prices are very low compared too Norwegian (just bougth Hella E code headlights for my car from a US dealer for just above a 1/4 of the Norwegian price)
but shipping are expensive, especially by air
Old 29th November 2009, 10:22 PM   #28
jamikl is offline jamikl  Australia
doug20. I am a bit thick today ( everyday maybe ) but could you do a diagram of your solution with the 100R resistor. I don't find the picture or the explanation clear. I am trying to connect an unbalanced preamp to an Ashley crossover. I have adaptor sockets but your solution is probably more viable.
jamikl
Old 29th November 2009, 11:29 PM   #29
Look at the attached file (bad paint drawing)
Both connectors are seen from the back side (solderside)
Grey= white lead with optional resistor (use the resistor if the cable are more than 12-15 feet long(
Red=red lead
Black= screen
Use standard microphone cable with one red, one white(or clear) lead + a screen
Old 30th November 2009, 08:53 AM   #30
Thanks for that FE3T.
jamikl
Does a digital crossover with RCA (unbalanced) input/outputs exist?Hide this!Advertise here!
Wiring for XLR input on unbalanced amp Arx Chip Amps 3 16th April 2007 07:57 AM
Does it exist: Dolby Digital Decoder Chip Or Board? 6f6 Parts 7 15th March 2007 12:05 AM
Need help with a BSS Digital crossover and distortion on unbalanced analog Ken L Multi-Way 4 9th November 2006 02:14 PM
ESP 101 with balanced/unbalanced input Cloth Ears Solid State 2 17th June 2006 12:12 PM
Unbalanced input SOZ? paulb Pass Labs 5 27th September 2001 06:01 AM
Copyright ©1999-2017 diyAudio
