Has anyone used the CIARE 1.38 TW TWEETERS?
#2 |
No I haven't used them, however I was looking at using those in a high-efficiency 2-way ported enclosure I am designing for my SE tube amp. The woofer I am looking at is the Eminence DELTALITE® II 2510 Neodymium. It is a 97.3dB sensitivity speaker. I don't have room for anything big. It looks like the F3 in a 2 cu.ft. enclosure is 46Hz. Pretty good for a small enclosure.
#3 |
Quote:Recommended for professional audio as a mid/hi or full-range and monitor; also for bass guitar. Works well in sealed or vented enclosures.
Driver: http://www.eminence.com/pdf/deltaliteII2510.pdf Box: http://www.eminence.com/pdf/cab-deltaliteII2510.pdf Once again, no off axis measurements from the manufacturer. |
#4 | ||
| Has anyone tried the Ciare 8.50 NdMR or the Ciare 6.38 NdMR in a front horn? | pk | Multi-Way | 6 | 10th January 2009 09:42 AM |
| Ciare tweeters | Tomac | Multi-Way | 15 | 3rd February 2006 01:25 PM |
| Ciare 250 | Nuuk | Full Range | 190 | 7th December 2005 03:55 AM |
| Ciare PW 455 | Ruben | Multi-Way | 2 | 3rd December 2004 11:50 AM |
| Page generated in 0.07249 seconds (74.08% PHP - 25.92% MySQL) with 10 queries |
