I'd like to be able to see where different size drivers start beaming, and at what point it becomes 'severe'. I've noticed that it starts gradually, but then changes more rapidly, hence my wanting to see actual data. My ideal set of info would show me a 10" driver, an 8", 6" and 4", at angles up to 90deg off axis (all done by the same person). Sometimes mfrg datasheets show a couple of angles, but that isn't enough to do a good comparison.
I'd like to cut a hole in the side of my house, and do it myself, but I don't think that would be 'allowed'. Maybe the roof? EDIT: maybe it needs stating - measurements should be on an 'infinite' baffle
double complete rainbow all the way!! Last edited by cuibono; 20th November 2009 at 04:15 PM. |
#2 |
There are old nomographs for the -6db point based in driver diameter. You can also do simulations in some software as well. The first attachement is an old JBL graph the second an 8" JBL 2118 directivity graph generated in LEAP
Rob |
#4 |
Yeah, thanks, that is useful. I wonder to what degree it is accurate?
double complete rainbow all the way!! |
#5 |
Robh, I think the nomograph along with many other studies is NDA from JBLs development department.
#6 | |
Rob Directivity - Lansing Heritage Forums |
#7 |
Google for ARPE - Asymmetrical Response Pattern Estimator
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan |
#8 |
Lots of good info, thanks! I've realized SoundEasy also does polar pattern prediction.
#10 |
A bit off topic, but what are the reasons for avoiding 'beaming'?
When I first started here, I asked about a 2 way design with an 8 inch midbass, and beaming was sighted as a possible issue. I've heard mention of off-axis response suffering from this phenomenon, and that can erode imaging, is that correct? I'm confused as some call 12 inch drivers as 'mid-bass' and sight the narrowed dispersion as a positive. Is this a case of two different system goals and two schools of thought? Jim |
| beaming? with a large Full range with wizzer | pforeman | Full Range | 0 | 10th May 2009 01:34 AM |
| beaming? with a large Full range with wizzer | pforeman | Full Range | 0 | 10th May 2009 01:24 AM |
| What exactly is beaming and why does it matter? | paulspencer | Multi-Way | 101 | 13th June 2006 12:29 AM |
| Is beaming affected by volume? | Cal Weldon | Multi-Way | 4 | 13th November 2005 01:46 PM |
| Test studies | the_wonderchild | The Lounge | 0 | 7th August 2004 02:10 AM |
| Page generated in 0.11020 seconds (76.92% PHP - 23.08% MySQL) with 11 queries |
