#11 | ||
The speaker's timbre comes from both direct sound and reverberant field. When you mate an acoustically small tweeter to an acoustically large mid-range there's a decrease in power response as the mid-range beams followed by a jump back up. Quote:
However you get there uniform directivity sounds similar; although with increased directivity the speaker is less sensitive to room and placement issues and retains clarity farther into the room. |
#12 | |
frugal-phile(tm)
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi p10-hifi forum here at diyA |
#13 | |
Take the Speaker Voltage Test! |
#14 |
Please excuse my uninformed question, but could you Gurus please advise at 'about' what frequency (given various constructional parameters as mentioned) most woofers would start beaming? say 8, 10 12 and 15 inch? Grant.. I'd really appreciate this info... |
#15 |
Hey Grant, it's all in the charts above. Or look at the specs for Selenium drivers, they provide good polar plots.
The baffle is only going to make a difference where the pattern gets out to 180º and beyond. There will always be some bounce of the baffle, but less and less as the pattern tightens.
#16 | |
an 8" driver is -6dB at 90 degrees off axis at ~1440Hz a 10" at ~1440*8/10 a 12" at ~1440*8/12 a 15" at ~1440*8/15 a 6.5" at ~1440*8/6.5 For an 8" driver to be 3dB down at 90 degrees off axis, the freq. is 1050Hz You can calculate for the other driver sizes the same way as above, although you would want to use piston size rather than frame diameter, using the frame size is a ballpark figure. These are theoretical values for perfect pistons, but are actually fairly close to real driver behavior in all but very sloppy cone/dome drivers.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan Last edited by Ron E; 22nd November 2009 at 02:21 PM. |
#17 | |
The 128H is good up to about 900hz or so before it rolls off. A 2214 goes on above 1.2K. If you look at how JBL used them the 128 is in the 4412 monitor which is a 3 way and the 2214 is used in the 4425 which is a 2 way CD design and crosses over at the -6db point at about 1.2-1.4K. You can't use a 128H in a 4425 so you won't match the directivity at crossover with the horn used in the 4425. Rob
"I could be arguing in my spare time" Last edited by Robh3606; 22nd November 2009 at 02:32 PM. |
#18 |
Pano, Ron and Rob,
I made a mistake, oops! I'm using a lowish resolution plasma TV as my monitor and when I originally clicked those plots the detail was very hard to read. Now, after downloading and magnifying in an image editor.. all is revealed. Thank you all for your great advice. |
| beaming? with a large Full range with wizzer | pforeman | Full Range | 0 | 10th May 2009 12:34 AM |
| beaming? with a large Full range with wizzer | pforeman | Full Range | 0 | 10th May 2009 12:24 AM |
| What exactly is beaming and why does it matter? | paulspencer | Multi-Way | 101 | 12th June 2006 11:29 PM |
| Is beaming affected by volume? | Cal Weldon | Multi-Way | 4 | 13th November 2005 12:46 PM |
| Test studies | the_wonderchild | The Lounge | 0 | 7th August 2004 01:10 AM |
| Page generated in 0.11457 seconds (80.90% PHP - 19.10% MySQL) with 11 queries |
