#11 |
on the positive side, the jbl 2225h would be good for a DJ system, the usual approach would be to put this driver in a vented cab and combine it with a compression driver/horn above 1200Hz
‘today… there lives alongside the twentieth century the tenth or thirteenth. A hundred million people use electricity and still believe in the magic power of signs and exorcisms” Trotsky |
#12 | |
Banned
#13 |
just for the hell of it, if you're desparate you could connect the small speakers, say a 4 ohm in series with an 8 ohm, and parallel the two pairs, which will give you 6 ohms.
You will still need a crossover for these drivers, I'd use 3rd order. use the tweeter section from this calculator: Crossover Design Calculators I doubt that it will sound great though...
#14 |
Well I'm gonna give you advice that noboddy on here might like. That is now if you get my post in time, as my posts are still under moduration that seems to be forever
![]() Use the JBL's in a 50 to 80 liter vented box each. I would go for bigger and tuned to around 50 to 55 Hz. X over at the recomended 1200 Hz to the 6X9's. Connect 2 x (6x9's) in series to give 8 ohms, and lastly connect a good piezo or two to cover the high's. Take note, piezo's are not great, but if you are on a budget, and in a hurry, it could save the day. Piezo's don't require x-overs, but I would still add a x-over to limit the 6x9 to 3500 Hz. This solution is not great, but imo the best that you can do with a limited budget. To get a compression driver that can X at 1200Hz is going to cost you a arm and a leg, and propper PA mids with a cheaper compression driver won't come cheap either. |
| I am desperate for help with my amp | seafire | Solid State | 24 | 25th November 2009 03:42 AM |
| desperate help needed for p.a design | luke691 | Instruments and Amps | 15 | 13th January 2008 05:41 AM |
| Please help me with my new QSC MX-700!!! Im desperate! | O_ROD | Subwoofers | 5 | 6th April 2007 11:07 AM |
| desperate need of help for op amps | theChris | Everything Else | 8 | 30th December 2002 04:12 AM |
| Page generated in 0.07858 seconds (84.40% PHP - 15.60% MySQL) with 10 queries |
