Old 23rd November 2009, 08:47 PM   #31
I think you'll find that the rule "baffle to back panel spacing should be between (and not too close to either) one quarter and one half wavelength at the driver crossover frequency" is not too limiting in terms of cabinet construction. The point is that if the resonance is above the driver passband, it won't be excited and thus won't have to be damped.
Regarding lining/stuffing, I've examined many of the Philips speakers of the period (the "Hi Fi DIN 45500" era). They were all 1/2 to 2/3 full of high density fibreglass batting. This filled all the space between the rear panel and the rear of the drivers. This was enough to provide useful absorption of front-back resonances, and provided high absorption of top-bottom and side-side resonances.
Driver complement was usually AD7066, AD8066 or AD12100 woofers, AD5060 midrange, and AD0140 or AD0160 tweeters.
Regarding leaving a large amount of room for the drivers to "breathe", my opinion is that this belief has little or no scientific validity. It is at odds with the body of practical experience gained from various woofer enclosure topologies, which can be summarised as "leave at least as much area as the driver's diaphragm area". Even if the back panel is hard up against the magnet (assuming no pole vent), the area of the cylinder around the driver that all the air has to pass through is still several times the diaphragm area.
So provided that the possible resonances (especially front to back panel) are well above the driver passband, where is the mechanism that could prevent the driver from "breathing"? Could it be that moving the rear panel further away from the driver, thus moving the resonance into the passband, alters the sound in a way perceived to be euphonic?
Another topic raised above is non-resonant reflections ("echoes") from the rear panel. Again, a small spacing is better, as the reflections will be closer in time to the original wavefront. The reflection timing in the classic "wide baffle / shallow enclosure" speaker will be in the same range as the baffle step timing. Proper dimensioning can make the reflection coincident with the baffle step, reducing its effect.
Note that I'm not advocating a return to the classic "large baffle". In my opinion, baffles should either be as small as possible or as large as possible. Their spatial and temporal effects should be minimised, and kept as far away as possible from the drivers when not avoidable.
Old 23rd November 2009, 08:54 PM   #32
frugal-phile(tm)
planet10's Avatar
I work mostly with full-range drivers, so perhaps a worst case situation. I have found that if i do not allow sufficient space to the sides of the driver cutout, or if the back panel is too close to the driver, i get colourations that i vcan remove by giving more room to "breath".
I have also found that an angled rear wall has some positive benefit, althou not always commensurate with the extra effort involved.
If you are doing a multiway, then one has to consider the wavelengths involved. In a woofer cabinet the wavelengths are such that almost any box is small. In these thou transmission-lines tend to reduce time-smear by "sucking the back wave down the line".
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 23rd November 2009, 09:21 PM   #33
badman is offline badman  United States
Custom Title
badman's Avatar
Concern about the passband is all well and good.... except that we're talking about real-world speakers here, not brickwall filters. So in many cases a few octaves away is still quite audible
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 23rd November 2009, 11:18 PM   #34
Yes, my remarks don't apply when the driver's passband includes the front-rear resonance. In that case you need to move the walls back far enough to allow sufficient damping material to minimise the reflections. Note that just moving the walls back is not enough - there has to be damping, because the amount of energy reflected back is constant regardless of the distance, for any practical enclosure size. In other words, you get just as much reflection if you give the driver room to "breathe", it's just delayed in time. That will certainly alter the sound character, but is it better?
dave
You do indeed have to consider the wavelengths. And when you do, you will find that the dimensions are not as free as you think. For example, in a two-way, you need to allow for frequencies up to 1 or 2 KHz in the passband. For 1 KHz, that means the front-rear distance should be less than 17 cm (about 6 inches). Keeping well away from 1/4 and 1/2 wl, and allowing for out-of-band response as pointed out by badman, means you should aim for about 4 inches front to back. For a 2 KHz crossover, the situation becomes almost hopeless - better to go for a deeper cabinet and damp the resonance.
Old 23rd November 2009, 11:46 PM   #35
All of this assumes that the amount of energy reflected back through the cone is sufficient to cause problems. It depends on a number of factors. For example, I would expect the problem to be worse with full-range drivers with their light cones. I propose a simple experiment:
Take a driver in an enclosure. Mount an identical driver over it, face to face, with its terminals shorted together. Listen to what comes through the back of the second driver. This is a "worst case" scenario, but it will give you an idea of the magnitude of the problem. Remember that all of the energy radiated from the back of the driver in an enclosure has to go somewhere. Absorbed by the walls and damping in the anclosure, or back out through the cone of the driver.
Old 29th November 2009, 07:11 PM   #36
Today i placed the 1000's on heavy stands on there side with the tweeter facing in with a slight toe in.... This created a more stable image with voices being more central instead of the wall of sound effect. Not holographic spooky imaging but acceptable, the weakest point in an otherwise outstanding speaker.
Brilliant speaker, im going to try a diy high end bookshelf with some seas metal drivers in the future to see if they can out perform the yamaha's. To me i cant see any speaker at a resonable price outclassing them completly but maybe im wrong?
Old 30th November 2009, 05:43 AM   #37
Hennie is offline Hennie  South Africa
I think the Yamaha's will have much better dynamics than a system based on Seas metal drivers, but if well executed the latter will have much lower coloration in the upper bass / lower midrange area.
Old 2nd December 2009, 06:12 PM   #38
event horizon's Avatar
I don't think anything will ever beat the Yamaha Beryllium midrange I find it quite ironic that other speaker manufacturers have only cottoned on to this material in the last few years where as Yamaha was using it nearly a quarter of a century ago Still haven't seen anything other than tweeters us it yet though - they are miles ahead of the curve.
I'd tend to agree, there really is quite a bit of cone on the 12" bass to allow reflections from the rear baffle through. The carbon fibre bass unit of the NS1000X (also similar to the NS2000) does a better job in that area. On the NS2000 thay also added extra bits of wood at the side with 3/4" or 1" rounded edges to, which certainly helped with imaging
"Never let your morals prevent you from doing what is right!" Salvor Hardin
B20's, sealed, wide vs narrow baffle? 2litre Full Range 15 21st March 2010 08:30 PM
Advice needed for a wide baffle shallow box exurbia Multi-Way 10 23rd May 2007 11:30 AM
Fr125S: wide or narrow baffle bro Full Range 28 1st November 2006 09:15 PM
Possible wide baffle project Scottmoose Full Range 6 25th September 2005 01:16 PM
narrow vs wide baffle and port location....? AudioGeek Multi-Way 3 9th May 2004 09:19 PM
Page generated in 0.12521 seconds (83.14% PHP - 16.86% MySQL) with 11 queries
