Small HTIB System/Computer System Review
Old 19th November 2009, 02:59 AM   #1
form109 is offline form109  United States
Default Small HTIB System/Computer System Review
this Thread is on my Opinion about a Few Mini 2.1/5.1 systems ive owned in the Past.
First is the Regent HT-391Click the image to open in full size.
so far this is the best one i've owned...the sub is the best out of all the ones i've had..uses a 5 1/4 Paper Cone Woofer with a Vented Motor Structure..Pole vent was unexpected,Voice coil is 1" on an Aluminimum Former,30 Watt Rating Stamped on the Driver,4 Ohms,driver is unshielded.
Satatlite Drivers are 2.5" Paper Cone with a Paper Former,10 Watt Rating Stamped on Driver(s),6 Ohms.
the satalites are good as well,good midrange and good high frequency extension,stays Clear at High Volumes,the Rear Speakers are Unshielded,while the fronts and Center are shielded.
the sub however does distort if the bass is maxed out at high volumes...this is the amp clipping...overall its loud enough for most.
Next Comes the Durabrand HT-3917Click the image to open in full size.
This system is not quite as good as the system above,the weakest link here is the sub...it has practically no extension below 80 Hz.
The woofer is 5 1/4" like the Previous system,the driver is lower in quality,no pole vent in this one...20 Watt Rating Stamped on the Driver,4 Ohms,Voice Coil is Basically the Same 1" on an Aluminimum Former.
The Satatlite Drivers are 2.5" 4 Ohm Unit with 10 Watt Ratings,paper Cone with a Foam surround,Paper Coil Former.
The Satatlites Also Sound Good...what applies to the previous system for the sats also applies here.
3Rd on the list is the Altec Lansing BX-1021.
another fairly good sounding system.
Subwoofer uses a3"or 4" Driver with a 1" Aluminum Former Voice Coil,Partially Shielded with a Bucking Magnet,15 watt Rating Stampe on the Back,4 Ohm.
Satatilites use a 2.5" Driver with a Paper Cone,Fully Shielded,6 Watt Rating Stamped on Driver,8 Ohms.
the first HTIB System i owne...bought it in October of 2005,its long gone...24 Bucks at Walmart
Subwoofer is typical,unmodified it has a huge hump around 80 Hz to make it seem as it is real bass,but it cant help it,small woofer in a Enclosure Tuned too high...i still enjoyed it
Woofer was a 15 Watt Paper Cone Unit with a 1" Aluminimum Former Voice Coil,Shielded with a Bucking Magnet,4 Ohms.
Satatilite Speakers used a 2 x 3 Paper Cone Driver with a Neodymium Motor,sats were Clear and clean sounding.
Last edited by form109; 19th November 2009 at 03:13 AM. Reason: neede to add details.
Small HTIB System/Computer System ReviewHide this!Advertise here!
Computer Subwoofers and Cheap HTIB Subs form109 Subwoofers 5 19th November 2009 01:25 AM
Computer Speaker System MaXiMu5 Everything Else 0 8th February 2008 07:10 AM
Computer system -need advice BMD Multi-Way 1 5th March 2006 11:36 AM
tri-amped system .. computer as xo? kfr01 Digital Source 2 14th October 2004 01:54 PM
some hints on a computer speaker system demons_wing Chip Amps 0 30th July 2004 12:53 AM
