Old 18th November 2009, 05:30 PM   #1
Jidis is offline Jidis  United States
Default HF crossover below driver specs.
I've been fighting with crossover frequency/type decisions on a small pair of two-ways I built. I've been testing different virtual configs in software and feeding the hi/low drivers separately.
Problem is, the tweeter's frequency specs cut off relatively higher (3k) than many of the settings I seem to like. It's looking like I may end up with some 2nd-order variant there, but filters in the 1k-2.5k range seem to sound the least "scooped" and I'd like a slightly "pronounced" midrange.
Am I endangering my tweeters much more by running below cutoff like that, or is the spec more of a guideline saying their response is just going to be weak below 3k?
-Thanks!
George
PS (FWIW)- They're Pioneer soft poly dome tweeters:
* Power handling: 50 watts RMS/75 watts max
* Voice coil diameter: 1"
* Impedance: 8 ohms
* Frequency response: 3,000-20,000 Hz
* Magnet weight: 6.3 oz.
* SPL: 92 dB 1W/1m * Net weight: 1-1/4 lbs.
* Manufacturer model number: FBDE75-52F
Old 18th November 2009, 05:42 PM   #2
diyAudio Moderator Emeritus
Iain McNeill's Avatar
You mean the tweeter resonance is at 3KHz, they roll off below that?
Two problems with running tweeters low:
1: have to watch the power level, as you include more of the music spectrum, the tweeter has to do a bigger percentage of the work and can therefore be overloaded (i.e. burn out)
2: distortion rises very fast below resonance. This'll add some grunge/rasp to music peaks.
You really ought to XO above resonance by 0.5 octave for 2nd order but hey, try it. Might get some of that warm tube sound
Old 18th November 2009, 06:16 PM   #3
Hey Iain,
Yeah, I'm not sure what they really roll off at. I'm just going by the manufacturer's specs of the range they're supposed to handle.
That's the sort of info I was afraid to hear. I'm already unhappy with my choice on these HF drivers. I think I picked them by recommendation from MCM long ago. Indeed, they do have a somewhat buzzy harshness in that area. The cabinets are already routed out to fit these tweeters, but I planned to do a second pair later and may switch to something else.
They do sound nice and smooth with crossovers up higher, but they also have a bit of that "smiley face" consumer EQ sound to them, and I was trying to tune them for use as reference monitors on a small audio rig here. Slight harshness may not be all that bad for that if the overall response is accurate. I'll also see if there's anything I can do on the woofers to get a boost in that crossover region. That might enable me to get the tweeter up higher without losing so much. The woofers are supposed to make it up to 10k, but they don't sound like it. Maybe the impedance could be flattened some.
BTW- These won't be something I'll be pushing really hard (very close range, and only 4.5" woofers).
Much thanks for the advice!
George
choosing specs for driver that will be used for OB c3conv Multi-Way 3 21st November 2008 07:28 AM
help with driver specs threegee Subwoofers 19 24th April 2006 05:39 AM
help with components' specs for crossover piro Multi-Way 0 5th July 2005 06:55 AM
EAW 18" driver specs Graydon Subwoofers 26 7th November 2004 02:43 PM
Any specs on this JBL driver? Bull Car Audio 4 19th September 2003 08:21 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd.
Copyright ©1999-2013 diyAudio
