Red - finished 2 way project
After Black, a 3 way here is red, my latest project.
It is using an Audax AP210Z0 as medium-woofer and a Vifa XT25SC50-04 as tweeter...
Thanks for you appreciations!
I will try to post construction pictures soon...
Yes, the panels are non-parallel, 5 degrees for the front one, 3 for the back one and 20 for the top one...
It is a vented box with bracing inside.
I used some kind of primer and some layers of regular spray paint. A lot of layers actually, as I am not a great painter I had to fix a lot of mistake several times,. Almost a week of sanding, spraying...
As promised, here are a few construction pictures:
The developed idea using Sketchup:
The enclosures with their bracing:
The preparation of front panels using 30mm+25mm thick MDF boards:
The rough front panel curve made with a router:
Back-side view:
Front side view, after roughly sanding the front curve:
I don't have pictures of the tweeter head. It was made with a cheap Russian doll head...
Cool pics above but I was REALLY curious how you did the tweeter...very cool.
Even thoug you do not have pics could you explain how you did it?
Basically:
The Russian doll head had the same diameter as the tweeter. I made a piece out of MDF that was half a circle on the top and trapezoidal in the bottom. This piece has a circle opening for the tweeter. The doll's head is glued on its back.
The trapeze part fit into a groove on the top panel and sealed with some AB components.
It also has two holes for the wiring...
