Old 17th November 2009, 12:50 PM   #1
fb is offline fb  Australia
Default How sealed is sealed?
How can I tell if my sealed boxes are sealed well enough? There doesn't seem to be any shortage of bass, but I've not tried anything too arduous.
Is it possible to tell from these impedance graphs?
Old 17th November 2009, 01:00 PM   #2
Glowbug is offline Glowbug  United States
Glowbug's Avatar
As long as your cuts were straight, joints are tight, used adequate glue/sealant...I wouldn't worry too much about it
Jim J.
Old 17th November 2009, 01:23 PM   #3
Zen Mod is offline Zen Mod  Serbia
Zen Mod's Avatar
take 3V battery
apply voltage to speaker ; disconnect ;
if speaker is really sealed , then cone will travel back much slowly comparing to same speaker in BR box or out of box ;
you can try to listen around baskets of all drivers in box - every air leak is pretty easy to hear
be careful , don't push your ear in cone
my Papa is smarter than your Nelson !
tnx to clean thread ; Cook Book ; PSM LS Cook Book ; Baby Diyaudio FORUM ; BAF Forum & Gallery;I'm dumb
Old 17th November 2009, 01:51 PM   #4
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Are both plots from two copies of the same speaker? One reveals a resonance around 160Hz that is probably adding colouration...
I use to feel like the small child in The Emperor's New Clothes tale
Old 17th November 2009, 02:41 PM   #5
badman is offline badman  United States
Custom Title
badman's Avatar
and the other has lots of small ripples.... I think it's box stuffing time!
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 17th November 2009, 03:21 PM   #6
Dr.EM is offline Dr.EM  United Kingdom
Dr.EM's Avatar
Is sealant required around the inside joins if the panels have been bonded with glue all along? If so, what is suitable to use?
Old 17th November 2009, 03:25 PM   #7
Did it Himself
richie00boy's Avatar
No you don't need sealent if your glue joints are sound. I just run my finger along the excess anyway to act as a sealer.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 17th November 2009, 04:21 PM   #8
frugal-phile(tm)
planet10's Avatar
You beat me too it... likely a panel that is not well enuff braced.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 17th November 2009, 08:14 PM   #9
I don't worry too much about sealing any more. Even drilled a whole (1/16") in the back of my speakers to allow for static air pressure equalization because I had the feeling the box was too airtight.
Best, Markus
Old 17th November 2009, 10:06 PM   #10
Iain McNeill's Avatar
If you want to tell from the impedance curve, you have to compare it to the impedance curve for the same driver in free air, away from reflective surfaces. When you put the driver in the enclosure, the impedance peak will shift up and the Q will rise in accordance with the T-S relationships with Vas and Vb. If you're not getting all the frequency & Q rise, then there must be a leak.
Joseph d'Appolito's "Testing Loudspeakers" explains all.
Sealed ZRT or sealed ZD5 sapek Multi-Way 2 8th May 2009 05:32 PM
Sealed box to OB? mayhem13 Multi-Way 11 23rd February 2009 02:14 PM
NSB, sealed? 2litre Multi-Way 1 23rd November 2008 02:14 AM
W8-740 in sealed sub? toseland Subwoofers 2 1st December 2004 07:48 AM
Sealed midbass vs BR, why not sealed ? mbon Multi-Way 3 16th June 2004 10:50 AM
Page generated in 0.10917 seconds (81.54% PHP - 18.46% MySQL) with 11 queries
