Old 16th November 2009, 08:44 AM   #1
thadman is offline thadman  United States
Default Variable tension apparatus for transducer analysis
I'm interested in building a ribbon loudspeaker in my free time over Christmas break and would like to drive it directly. Following the resolution of some meetings with faculty in the engineering department, I might be able to gain access to the Universities Laser Vibrometer and Anechoic chamber for measurements (and comparison with the RAAL 140-15D).
I've conducted significant research within the AES E-Library as well as my Universities research library with regards to ribbon transducers. Only a few articles have been published, and of those, very little research regarding the behavior of the membrane was conducted.
Assuming I can get access to the Universities measurement equipment, I'd like to do testing on a variety of transducer alignments, specifically low and high compliance membranes.
Haphazardly clamping the membrane does not appear to possess the rigor necessary for a scientific analysis of transducer behavior.
To achieve an accurate correlation between experimental and simulated results, it will be necessary to apply a very specific, measurable force at the ends of the membrane.
I'm not sure how/where to build/purchase/acquire access to such a specific machine...or even what to google. If any users could provide help with regards to the aforementioned topic, I would be very appreciative.
Thanks,
Thadman
"It is a profound and necessary truth that the deep things in science are not found because they are useful; they are found because it was possible to find them."
Old 16th November 2009, 12:26 PM   #2
You might try looking into tensile testing equipment like that made by Instron
http://www.instron.us/wa/product/330...g-Systems.aspx
They and others can measure very small stress and strains on strips of materials down to very low levels.
A tweeter ribbon is a narrow long strip of matal.
Re-Jigging the jig: Speaker testing device for Arta, Speaker Workshop & HOLMImpulse MJL21193 Multi-Way 263 9th January 2012 11:24 AM
NTC in High Tension PSUs? Salas Parts 4 20th February 2008 11:50 AM
Change of tension in a Classe CDP dario54 Analogue Source 1 27th October 2007 06:58 PM
How to measure diaphragm tension 405man Planars & Exotics 15 11th May 2007 02:00 PM
Tension on chassis eduard Tubes / Valves 35 31st July 2003 12:00 AM
Page generated in 0.06673 seconds (67.63% PHP - 32.37% MySQL) with 10 queries
